Ungrouping a group
Hi everyone!
I did stupid mistake now i want to fix it.
I grouped part of my model and then I've added in to a layer that OK, but then I changed my mind and from the same group I've create another layer, now...
first layer I can show/hide by checking/unchecking in the layer window, the second layer i can't show/hide until i check the first layer that's because this two layers are in the same group so.... i want to ungroup this part (or whateve it is) and create separate group for this two layers. I.... found something about this problem here
http://sketchup.google.com/support/bin/answer.py?hl=en&answer=95642 but I can't see that "Ungroup" menu item???So.... can someone help me
pleeease
erm... Sorry for my English. (If there is some grammar mistakes
right click on your group and choose explode.
Just... that... That's it!?!?! I did it !!! Thanks man!
Thaaanks! You hear that
It's simple but when you don't know where it is...
Well done
my pleasure. i know how frustrating the little things can be.
Thanks for your answer, xrok1.
Unnecessary confusing UI - should be directly in the edit menu under Group, right?..
It is in the main menu too ?
The context-menu varies with the selection, and it is replicated in drop-down menu associated with the last item in the Edit menu.
The title of the last item will vary depending on the selection - here, for a group it'd say 'Group' etc - like Entity Info does...
With your input, this post could be even better ๐
