    Line ,Polyline, Perimeter Ratio Divider or Extender w/
    15 Posts 8 Posters 3.9k Views 8 Watching
    • J
      jessemorton24
      READ at risk.=>> A divider at 1 / Phi or Extender to Phi (pronounced FEE, so I read at Discovery Channel). This would be the absolute great command...[Mars and Venus rotate around each other being from a third point the earth, so I read.. And that Jesus's tribe of Judea looked at this religiously and saw change the movement change that lead to weird natural events, which it has been theorized through complicated nasa animation software of these exact moments visually from each historical spots on plant earth.]
      Somehow with Phi or 1 / Phi lines in Sketchup, at a divided or extended percent of the selected line, this could be an efficient function to explore the beauty of natural growth within a sketch. Perhaps Phi Curves with this being of a distance percent divided at this loving, beautiful ratio for an offset command.
      [By the way, the North Star was theoretically proven to be Mars and Venus Appearing to collide for a long, abnormal length of time creating twice the brightness and natural disasters proven by nasa animation software.]
      Thought Revision: SORRY, for that Sketchucation. I'm just trying to sell the idea.. I forgot to put a parenthesis somewhere and I shouldn't use them anyway according to my old college prof. I just know this would be sweet.. cause I draw too many construction lines over lines already to find the ratio.. I don't really care for the tape measure tool, although it could be used as a way to measure. Time would be saved for me.. Considering I try to keep it sacred......w/ sacred geometry triangle..square..pie circles..etc.
      Parkways, Driveways, Gateways, Pathways...
      • X
        xrok1
        wow 😲 👊
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        • R
          remus
          Indeed. Could you please spend a little more time writing your posts? they're very hard to decipher at the moment which makes discussing them quite hard.
          • J
            JuanV.Soler
            @jessemorton24 said:
            A divider at 1 / Phi or Extender to Phi (pronounced FEE, so I read but not by hearsay). This would be the absolute best..mind us, Mars and Venus rotate around each other being from a third point the earth, so I read.. And that Jesus's tribe of Judea looked at this religiously and saw change the movement change that lead to wierd natural events, which it has been theorized through complicated nasa animation software of these exact moments visually from each and historical spots on plant earth.)
            Somehow with Phi or 1 / Phi lines in Sketcup, born of this idea of a divider percent fumction.. Perhaps PHi Curves with this being of a distance percent divided at this loving, beautiful ratio.
            By the way, the North Star was theoretically proven to be Mars and Venus Appearing to collide for a long abnormal length of time creating a twice the brightness.
            yes, but Jesus also said not to worry for enough has its days
            not to worry about the future
            very hard
            it must not be the golden line the solution, that should be a very terrible ending.
            it must be other thing, better than gold
            the gold we now
            • thomthomT
              What are you lot talking about and how does it relate to SketchUp? ❓ 😕 😲
              p.s. please don't use all caps - even for thread titles.
              • jeff hammondJ
                jeff hammond
                i haven't a clue either but i'll take it! hurry up google 😄
                dotdotdot
                • J
                  JuanV.Soler
                  there is problem with SketchUp when you try to make sacred geometry,
                  and that is that you will never get a proper circle, for instance.
                  did you know that ?
                  • J
                    jessemorton24
                    did you know that ?
                    Yes, but I think that by commanding this plugin to draw a line from center of a 'radius' and taking a .61803399 of the distance from the radius line drawn then you can ultimately get an offset sacred semented circle. Or perhaps linking an area function to the plug-in doing the perimeter command.
                    Pie is irrational. No one can tell if a circle is actually round that i know, but in the same class of importance as Euler's constant or even i (the bang) of infinity. Zero and 1 are just as important, as well. Maybe if Sketchup can Rotate by the limit of the sum segmented then we could get a never-ending number.. But Sketchup rounds which probably gives rise to little holes in our curvy objects. A proper circle might indeed exist but we might never know in this world. For now Sacred to me is what Archimedes segmented giving rise to what he called pie circles.
                    • C
                      chrisjk
                      Have you been taking lessons from Durant?
                      Chris
                      • R
                        remus
                        Having done a bit of background reading, i think i understand the idea: basically have inference at the golden ratio (or phi to use the OPs terminology.) I dont agree that it should be included as standard in SU though as i think it is too obscure to be of interest to the majority of users.
                        Some of what you described might be workable in a plugin though, just a matter of writing it really.
                        wiki link: http://en.wikipedia.org/wiki/Golden_ratio
                        • thomthomT
                          You do get Golden Ratio inference with the rectangle tool.
                          I agree with remus here - this sounds rather specialised. Infering an offset based on the radius. Plugin candidate I'd say.
                          • GaieusG
                            Rick has a golden ratio plugin somewhere at Smustard (or here at SCF?)
                            • J
                              jessemorton24
                              NICE!!! I know scaled and grouped object gauge plays a huge part to be simple. I think it could be tweeked to show dashed lines upon indicating the points at which the command then executes.. This might be a great solution in the mean time.
                              Cheers!! Nice name by the way!!
                              • J
                                JuanV.Soler
                                i have not found it in the SCF,
                                there is a Rick ruby called GOLDEN GAUGE,
                                go on then Jesse
                                • GaieusG
                                  That's it, thanks Juan!
