    Line ,Polyline, Perimeter Ratio Divider or Extender w/
    15 Posts 8 Posters 3.8k Views 8 Watching
    • jeff hammondJ
      @thomthom said:
      What are you lot talking about and how does it relate to SketchUp? ❓ 😕 😲
      i haven't a clue either but i'll take it! hurry up google 😄
        JuanV.Soler
        @jessemorton24 said:
        .. Considering I try to keep it sacred......w/ sacred geometry triangle..square..pie circles..etc.
        there is problem with SketchUp when you try to make sacred geometry,
        and that is that you will never get a proper circle, for instance.
        did you know that ?
          jessemorton24
          did you know that ?
          Yes, but I think that by commanding this plugin to draw a line from center of a 'radius' and taking a .61803399 of the distance from the radius line drawn then you can ultimately get an offset sacred semented circle. Or perhaps linking an area function to the plug-in doing the perimeter command.
          Pie is irrational. No one can tell if a circle is actually round that i know, but in the same class of importance as Euler's constant or even i (the bang) of infinity. Zero and 1 are just as important, as well. Maybe if Sketchup can Rotate by the limit of the sum segmented then we could get a never-ending number.. But Sketchup rounds which probably gives rise to little holes in our curvy objects. A proper circle might indeed exist but we might never know in this world. For now Sacred to me is what Archimedes segmented giving rise to what he called pie circles.
          Parkways, Driveways, Gateways, Pathways...
          • C
            chrisjk
            Have you been taking lessons from Durant?
              remus
              Having done a bit of background reading, i think i understand the idea: basically have inference at the golden ratio (or phi to use the OPs terminology.) I dont agree that it should be included as standard in SU though as i think it is too obscure to be of interest to the majority of users.
              Some of what you described might be workable in a plugin though, just a matter of writing it really.
              wiki link: http://en.wikipedia.org/wiki/Golden_ratio
                You do get Golden Ratio inference with the rectangle tool.
                I agree with remus here - this sounds rather specialised. Infering an offset based on the radius. Plugin candidate I'd say.
                • GaieusG
                  Rick has a golden ratio plugin somewhere at Smustard (or here at SCF?)
                    jessemorton24
                    NICE!!! I know scaled and grouped object gauge plays a huge part to be simple. I think it could be tweeked to show dashed lines upon indicating the points at which the command then executes.. This might be a great solution in the mean time.
                    Cheers!! Nice name by the way!!
                      JuanV.Soler
                      i have not found it in the SCF,
                      there is a Rick ruby called GOLDEN GAUGE,
                      go on then Jesse
                      • GaieusG
                        That's it, thanks Juan!
