    Simple reflection
    7 Posts 6 Posters 1.6k Views 6 Watching
    • G Offline
      georglorenz
      I have a crazy idea on how to maybe add simple reflectivity to a material. Unfortunately I am not a ruby expert at all, but maybe someone else would want to take on this little project. The script would do something like this:
      • Save the current viewpoint
      • Get a face from the user selection
      • set the viewpoint in the center of the face, looking at the reflected angle to the original view
      • render this view
      • apply the rendering as the material to the selected face
      • return to the original viewpoint
      I guess it will never be photo-realistic but maybe the effect is interesting.
      What do you think? G
      • Al HartA Offline
        Al Hart
        This idea would work.
        Another idea one our our clients used to get a reflective floor was to mirror all the geometry through the floor, and make the floor itself partially transparent.
        Al Hart
        IRender nXt from Render Plus
          Isn't there a tutorial on this site that demonstrates this to create reflection for a lake?
          • simon le bonS Offline
            simon le bon
            I remember it myself but can't find it again.
            Mirror or Reflection.
            Simulating a Reflection in Google SketchUp by Eric Lay(boofredlay)
            A time for reflection by Tyson Kartchner
            simon
            • G Offline
              georglorenz
              That's right! A mirror is a projection of the object through the plane of the reflecting surface! That could work with any surface not just the floor is what you are saying. Very clever. So the script could also
              • mirror the complete geometry of the model around the selected face
              • make a section cut through the plane of the selected face
              • saving the resulting image
              • projecting it on the selected face
              • and then undo the translations.
              Now that sounds like an evening program for the next half year. Thank you for your answers. G
                When making reflexions this way by 'mirroring', it's a wise idea to make the relevant parts of the main model and the 'handed/flipped 'reflection' using the same component [i.e. make a component of the main parts then copy it and flip etc to mimic the reflected objects] - that way when you change something in the room's component entities it'll also change in the "reflection's" entities too... 💭
                • FlatchoumF Offline
                  Flatchoum
                  I tryed this way of creating a reflective floor, the problem is when you render the scene with shadows, they go straight in the ground and don't change their direction as symetrically as they 'd do in real life (on a reflective face); I mean the shadows have the same slope in the whole scene, including the "reflection". But this is only a detail...
