    Distace from Camera to object in drawing.
    44 Posts 14 Posters 43.5k Views 14 Watching
    • Al HartA
      Al Hart
      I would like to be able to move the mouse around on a drawing and view the distance from the camera to the object near the mouse.
      I know I could write a tool to do this, but there is probably one out there already. Can someone point me in the right direction?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • GaieusG
        Hi Al,
        Here is one - by Rick - and it's free!
        http://www.smustard.com/script/CameraDistance
        • J
          Jim
          Maybe Fullmer (or you) can add this to his Onscreen plugin:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=16837
          • Al HartA
            Al Hart
            @gaieus said:
            Hi Al,
            Thanks, I'll give it a look. 🤓
            Al Hart
            • Chris FullmerC
              Oh Jim, that is an old plugin. I should look at it again. i can't believe it works at all!
              Chris
              All my Plugins I've written
              • J
                Jim
                Oh sorry - I know how you feel!
                • Al HartA
                  Al Hart
                  @gaieus said:
                  Hi Al,
                  This one returns to distance from the camera t the eye.
                  I would like to have a tool which lets you determine the distance from the camera to arbitrary objects in the drawing. I want to use it to set Focal Lengths for Depth of Field calculations.
                  This is not a good example, because the eye may be in the same place as the center of focus, but if the eye were raised up a bit, then it would probably be way behind the desired focal point.
                  http://wiki.renderplus.com/images/thumb/f/fa/Dof-100-1.0.jpg/350px-Dof-100-1.0.jpg
                  Al Hart
                  • thomthomT
                    Ah - yes. That would be a good tool. And for my use, since I'd use V-Ray I'd want it to display the distance in inches as well as model units.
                    Not sure if there's a tool like that out there though.
                    • TIGT
                      Assuming that you have something selected then
                      model=Sketchup.active_model
                      eye=model.active_view.camera.eye
                      ss=model.selection[0]
                      distance=eye.distance(ss.bounds.center)
                      returns the distance from the camera's 'eye' to the 'center' of the selection's bounding-box...
                      You can of course improve this - another way to get the distance to the 'face' of a selection would be to get the vector between the 'eye' and the 'center' and then do a 'raytest' to find the first point hit and get that distance...
                      distance=(model.raytest[eye, eye.vector_to(ss.bounds.center)])[0].distance(eye)
                      This then returns the 'distance'...
                      You can improve it further by testing if the second item in the returned raytest array contains the selected object and if not redo the raytest from the first item [point] in its array along the same vector...
                      vector=eye.vector_to(ss.bounds.center)
                      rayt=model.raytest[eye,vector]
                      pt=rayt[0]
                      while not rayt[1].include?(ss)
                        rayt=model.raytest[pt,vector]
                        pt=rayt[0]
                      end#while
                      pt=rayt[0]
                      distance=eye.distance(pt)
                      Hope this helps... 😕
                      • Al HartA
                        Al Hart
                        I took the utilitiestools.rb script in SketchUp, which displays an X,Y location as you move the mouse and changed it to display the distance from the camera instead.
                        The heart of the change is this routine to display the camera distance:
                        	# get camera distance from the eye to a point at (x,y,0)
                        	def get_distance(target)
                        		model = Sketchup.active_model
                        		eye = model.active_view.camera.eye
                        		distance = eye.distance(target)
                        		# display in drawing units and inches
                        		slength = Sketchup.format_length(distance) + sprintf(" (%g\")", distance)
                        		return slength
                        	end#def
                        Try the attached script: get_camera_distance.rb
                        [Edit: I uploaded a new version of get_camera_distance.rb]
                        Al Hart
                        • TIGT
                          But that measures the eye to target distance...
                          You want the eye to object distance ?
                          The object might be between the target and the eye positions !
                          See my example on how to use the eye>>>target vector and raytest from the eye along that vector for objects in between... perhaps using a selected object as the source [it needs work as it was only a first draft... but selecting a group/instance between the eye and target will give the distance to it ?]
                          • Al HartA
                            Al Hart
                            There was a bug in get_camera_distance.rb.
                            I uploaded a new version.
                            (One person had downloaded it already - sorry - please get a new version)
                            Al Hart
                            • Al HartA
                              Al Hart
                              I call get_distance(target) with the point from OnMouseMove() after calling pick(x,y) - not the target of the camera view.
                              I think it is working properly.
                              Here is a rendering after selecting the end of the cylinder as the target point and setting the Depth of Field to be very blurry (3.0).
                              Al Hart
                              • TIGT
                                I apologize... 😳
                                I hadn't read your script fully - your target isn't camera.target - you have a good idea - it works fine... 😎
                                • B
                                  Bertier
                                  hello
                                  could that plugin be used to create motion blur in an animation ?
                                  thank you.
                                  • M
                                    mpowell1234567890
                                    Cool, thanks. Love it when I can know how far away something is in a model. 😄
                                    [attachment=1:2q0r3qa8]<!-- ia1 -->get_focal_length.jpg<!-- ia1 -->[/attachment:2q0r3qa8]
                                    > 		return slength
                                    > 	end#def
                                    • P
                                      pibuz
                                      That is a lovely script, but it seems I'm not able to load it..
                                      How can I do that?
                                      Thanks a lot Al!
                                      **EDIT: ok, I moved the original utilities rb to another folder and renamed your script "utilitiestools.rb", and it works: now I can get camera distance 😎
                                      Is there a less homemade or brute method? 😆 Thanks again?
                                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Renaming files is dangerous.
                                        Make a subfolder of Plugins dir, named: !_autoload
                                        " %(#8000BF)[Plugins/!_autoload]"
                                        Then get my !autoload script here, and put it in Plugins folder.
                                        After.. you can put little scripts that you wish to autoload in the " %(#8000BF)[Plugins/!_autoload]" folder.
                                        I'm not here much anymore.
                                        • A
                                          angeli7on
                                          Hi, I got confused about this.
                                          I try using get_camera_distance but the result aren't DOF
                                          am I missing something ?
                                          here I attach my screen shot
                                          if too small I also upload here:
                                          http://imageshack.us/f/254/bingungdof2.jpg
                                          please advice, thanks alot.
                                          confusing dof
                                          • TIGT
                                            But the distance given by the tool is 703" - not '10' units in the Camera DOF dialog ?
                                            Try using the real equivalent distance [in the correct units for that dialog] to see what happens.
                                            The distance returned by the tool is the distance from the camera 'eye' up to the picked point - in your screenshot it's given in 'inches'...
                                            • 1 / 3
