    Hitting theSpacebar is Bringing Up the model Info Window
    7 Posts 4 Posters 532 Views 4 Watching
    • Tim DanaherT Offline
      Tim Danaher
      ...Anyone else notice this?
      I can't for the life of me figure out what's causing this....it happens sporadically.
      Cheers,
      Tim
      http://vizarch.blogspot.com
        Spacebar is Select by default shortcuts - have you changed them ?
          chrisjk
          http://forums.sketchucation.com/viewtopic.php?f=322&t=24452&p=219945&hilit=wild#p209295
          Chris
            Tim Danaher
            It's a conflict with Universal Access, apparently.
            Unfortunately, since I've only got one arm, Universal Access is rather important to me.
            Cheers,
            Tim
              Can't you change the settings for one of them ?
                tfdesign
                I seem to remember the spacebar being set to the select tool, and can't be changed, which is a shame because I too would have preferred the spacebar to be used for other purposes. Tim, perhaps you should email the SU dev team about this one? Being disabled does have some advantages too! 😉
                Tom 😄
                My book "Let's SketchUp!" Download from here
                  Tim Danaher
                  Actually, I'm on the Beta team, so I've gone through that channel.
                  I only have Sticky Keys enabled under UA. But turning off 'Enable Access for Assistive Devices' seems to do the trick. I think. Trouble is, that messes up my window switcher, 'witch' relies on that function to work. And I use it a lot.
                  Cheers,
                  Tim
