    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 961.6k Views 175 Watching
      Landie
      Thankyou for sharing. 😍
      http://www.smithdimes.co.uk
        New updated set available here... http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Brand new tool ExtrudeEdgesByRailsToLattice added.
        [It has basic EN-US/FR/ES lingvo files...] http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
        Replacement ES lingvo files for all tools included [from Defisto]; and some new FA lingvo files for some tools added [through Majid] - Thanks to them! πŸ˜„
        Minor adjustments:
        EEbyEdges tool now exits gracefully.
        A few scripts have had the missing "require 'deBableizer.rb'" added.
        RickW's ' offset.rb' method-only script is now included in the set - because it's needed by EEbyRailsToLattice...
        πŸ€“
        • mitcorbM Offline
          mitcorb
          Again, TIG:
          Thank you for your talents and contributions.
          • W Offline
            watkins
            Dear TIG,
            You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
            Regards,
            Bob
            offset.rb
              @watkins said:
              Dear TIG,
              Regards,
              Bob
              Don't know how I'm still using that old one !
              Finger on the pulse, and all that.... πŸ˜’
              Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
              I'll package the new version with any future updates...
              Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
              Sorry for any confusion...
                Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
                πŸ€“
                  I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
                  After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb πŸ˜’ .
                  None of this affects my tools - they only need the Face::offset() method !
                  In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
                  πŸ˜•
                    Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
                    [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
                    Thanks...
                      doy
                      thumbs up....this is hot...thanks a lot for sharing
                        Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
                        πŸ€“
                          Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                            Works fine now πŸ‘
                            • G Offline
                              gavvy
                              😲 TO Tig ,I can't say anymore πŸ‘
                                Here is an updated set.
                                EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                                Reverse the order of picking the rails to swap the diagonals' direction.
                                Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                                The lingvo files have be updated to match.
                                  Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                                  • W Offline
                                    watkins
                                    Dear TIG,
                                    Does one still need offset.rb? I notice that it is missing from the zipped folder.
                                    Regards,
                                    Bob
                                      Bob
                                      No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                                      You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                                        leixing
                                        Thanks TIG.
                                        great work
                                        • W Offline
                                          watkins
                                          Dear TIG,
                                          I understand from what you wrote that windowizer.rb has problems with offset.rb V2.1. Is that correct? I have overwritten my copy of V1.0 and I have windowizer.rb installed. Could you post a copy of V1.0 please?
                                          Thanks,
                                          Bob
                                          • W Offline
                                            watkins
                                            Dear TIG,
                                            Forget that last request. I've just checked and I have V3.0 of windowizer.rb. I downloaded it again and it had offset.rb V1.0 in the folder, so no worries.
                                            Regards,
                                            Bob
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 31
                                            • 32
                                            • 7 / 32
