    Colors of texture lost with vray4SU = HELP
    renderpluginsextensions
    4 Posts 2 Posters 581 Views 2 Watching
    • F Offline
      fbo_bern
      hi all
      this texture:
      with this bump_texture:
      results in:
      Processing step:
      1. made normal surface
      2. create new material with "alternating mudbrick" and color the surface
      3. ctr+a and made a group
      4. vray materialeditor: checkt displacement, bitmap, file "alternating mudbrick_b"
      5. multiplier "1"
      6. render
      question:
      why have the result only one texturecolor? Where is the bright and dark brown?
      thanks for help
      • F Offline
        fbo_bern
        okey, sorry.
        The error found! One must dye the group and not in the group the individual surface.
          Did you change the texture's colours using SU's material editor?
          Currently, VfSU doesn't match these types of materials well.
            @fbo_bern said:
            okey, sorry.
            That sounds very odd. Never seen that.
            But note: with the current version of VffSU, it will take for ever to process your scene before it starts to render if you apply materials to groups/components. So badly, that it's a big no-no to do so.
            but that has been fixed in the new beta.
