    How to connect three arcs ? [tutorial] round corner
    7 Posts 4 Posters 2.9k Views 4 Watching
    • S
      shalunn92
      How to fill the poligons betwen this three arcs in this corner (blue color) ? πŸ˜’
      Every time when i try to create poligons - it dont hear me and does whatever it want. πŸ’­
      http://s45.radikal.ru/i108/1001/53/61dfd257b5f0.jpg
        http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin
        check it out
        here's the video
        • TIGT
          Thanks Frenchy! πŸ˜‰
          Here's a similar EEbyRailsV2 way BUT with curved arrises of differing radii and distortion - the three examples show that what is chosen as the profile or rail can affect the mesh shape, smoothness etc as at some point the mesh must converge into a 'pointed end'... ❗EEbyRailsV2ConnectingRoundedCorners.png
            Some tests πŸ˜‰
            Difference visual aspect of faces is just "perspective"!
            Result is strictely the same! β˜€ (for orthogonal sides: not yet tested other cases πŸ˜„
            (click for zoom)
              You can also use Extrude edges by 2 rails by TIG πŸ˜‰
              Just Click again the first profil as Melding-profil
              Result is more or less rounding depending of choice πŸ˜‰
              Click if scrollbar
              • TIGT
                If you answer 'Yes' to the EEbyRails dialogs about erasing coplanar edges and smoothing, then it would look just like Fredo's straight away...
                My example shows unequal and distorted arcs etc which will give slightly different mesh smoothness depending on the order the curves are picked...
                  πŸ˜„
                  Yes ! I have missed this one in speedy pressing "No's Buttons" and want to make publicity for ThomThom tools πŸ˜†
                  And this can be post production πŸ˜‰
                  PS can you consider the 4 curves (2 profiles + 2 rails )of the EEbR as a Coons creator surface or it's another thing?
