    AutoCAD import problem
    2 Posts 2 Posters 831 Views 2 Watching
    • S
      Starlex
      Hi!
      I'm trying to import dwg/dxf model into Sketchup
      But i get double line instead one line
      How can solve this?
      autocad obj
      that's what i'w get in Sketchup. As ypu see, all lines are double
      • TIGT
        A CAD polyline is imported into SUp with a 'width' that will give double lines if it is >0, e.g. the polyline is 50mm wide in CAD so it comes into SUp as a 50mm wide 'ribbon'...
        To stop this use CAD to edit the file and filter, and set all polylines width=0, OR explode all polylines into ordinary lines before importing - If you don't have AutoCAD then apps like DoubleCAD are freeware that can edit dwg/dxf files and works with skp too...
