    [Plugin] Edge Tools
    211 Posts 74 Posters 294.5k Views 74 Watching
      It is doing what it should do and it it mathematically correct. You can extend those line segments with the Line tool. You could also try using Matt666's ExtendTool.
        rv1974
        Yes captain I realize that it's undoubtedly correct behavior. Initially I just asked Thomthom to extend his 'divide tool' (by accepting multiple edges)
          The key concept of the Divide Tool was that you didn't pre-pick edges. It was to allow you to quickly pick a reference edge and make a split. Multiple edges would be a completely different tool.
            rv1974
            ..would be completely different amazingtool πŸ˜‰
              Put file In V6 πŸ˜‰
              It's better for everybody! πŸ˜„
              An image ist sufficient! πŸ€“
                rumcajs
                Thanks to great plugin. It is something that i looked for, just it misses something.
                I have a REQ to update/upgrade.
                This is what I did:
                http://i47.tinypic.com/6sqpnd.png
                (the light red lines are original locations of the diagonals, which I tried to remove. You can see I succeed to removed only two).
                I had a scull which contains triangles and I wanted to reduce the triangles, so that I want to remove the diagonal of the rectangle shape area. Therefor I select two lines which are nearly parallel and the diagonal. Then I clicked the green colinear icon. It works to flat the edges onto one plane, so I can delete the diagonal. But if I want to correct the next area, then the previous area will generate diagonal... Here I am where I was on the start. Could it be possible to define the area (select faces), which is already fine and I won't be touched? So the edges of that face won't be touched?
                This is the point what I miss. A possibility to limit the edges to move (=forbid some edges/faces to move) and/or possibility to define angle, in which it can be moved.
                My original idea, before I found this thread was to have a definition plane, such as it is in the Fredo Scale tools (the Stretching with orientation of scaling box). So if you would have such orientation plane, you could define, where the plane should be moved (angle& position). Purpose of such plane is to define position and angle of the plane. Something like Fredo already did in his great Fredo Scale tools (they are good for control, and that is what I like and therefor mention here as good example). The plane needs only one direction to move, and this would define axis perpendicularly to the plane. I expect that the angle possibilities are defined by the selected tool and the differences between selected edges (so in my case, when I have 3 edges, only two angles are possible to infer - just an assumption).
                head 17 middle line corrected on eye center .skp
                  rumcajs
                  OK I attached file to previous post of mine. But I think the image is sufficient, and if you think it is not, then install fredo Scale tool, because the Stretching tool + twist tool, is enough to get inspiration.
                  • beginnerB Offline
                    beginner
                    ThomThom,
                    Really good plugin.
                    You can appreciate it if you work with AutoCAD files.
                    Thanks πŸ‘ πŸ‘ πŸ‘
                    Regards, SU 'beginner'
                      jorge2011
                      Thom, if I when be able use the new toolbar "architecture"?. πŸ˜„ thanks
                        Soon my friend, soon! πŸ˜„
                          jokewalker
                          @dedmin said:
                          Hey all,
                          Just installed 2.0.4 and am seeing this pop up again. Any simple fixes to make this go away?
                            Did you get-and-install the TT Lib that was linked on the download page ?
                              jokewalker
                              TIG,
                              I did have a version of TT_Lib2 in the Plugins folder already, but went ahead and re-downloaded/installed per your suggestion. Seems to be working now. Thanks!
                                sarkarshomit
                                Thanks ...very useful for me....
                                Shomit,
                                India
                                  @jokewalker said:
                                  @dedmin said:
                                  [attachment=1:6l2q4qpb]<!-- ia1 -->Capture.PNG<!-- ia1 -->[/attachment:6l2q4qpb]
                                  Hey all,
                                  Sounds like you extracted the content of TT_Lib directly in the plugins folder istead of preserving the TT_Lib2 that contains them.
                                    Mra
                                    thomthom, sweet script. However i'm having problems with one of your tools.
                                    The "Split faces into multiple pieces" doesn't seem to work properly on this face;
                                    http://i.imgur.com/At0My.jpg
                                    I can't give you the full scene though (NDA) and when I just paste this piece into a new sketchup scene your tool works. Any ideas? πŸ˜„
                                    Exploding object doesn't work either. The axis is at default place in the world at 0,0,0.
                                      Can you save a copy of the model - erasing everything else - purge the model, then send it to me?
                                        Mra
                                        Hi Thomthom, today is another day, so after I turn on the computer again, it seems there is no problem on the same piece of mesh anymore. Something must've been corrected when restarting SketchUp. Perhaps I ran into a bug by somehow? But anyway, thanks for your offer to take a look. If it ever happens again, I will try and get some reproducible steps.
                                          Ghost in the box. πŸ˜„
                                          • E Offline
                                            ErikLiu0801
                                            thanks a lot.
                                            i'm not good at english but i still want to say thanks for your sharing.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 8 / 11
