    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
      rumcajs
      OK I attached file to previous post of mine. But I think the image is sufficient, and if you think it is not, then install fredo Scale tool, because the Stretching tool + twist tool, is enough to get inspiration.
      • beginnerB
        beginner
        ThomThom,
        Really good plugin.
        You can appreciate it if you work with AutoCAD files.
        Thanks πŸ‘ πŸ‘ πŸ‘
        Regards, SU 'beginner'
          jorge2011
          Thom, if I when be able use the new toolbar "architecture"?. πŸ˜„ thanks
            Soon my friend, soon! πŸ˜„
              jokewalker
              @dedmin said:
              Hey all,
              Just installed 2.0.4 and am seeing this pop up again. Any simple fixes to make this go away?
                Did you get-and-install the TT Lib that was linked on the download page ?
                  jokewalker
                  TIG,
                  I did have a version of TT_Lib2 in the Plugins folder already, but went ahead and re-downloaded/installed per your suggestion. Seems to be working now. Thanks!
                    sarkarshomit
                    Thanks ...very useful for me....
                    Shomit,
                    India
                      @jokewalker said:
                      @dedmin said:
                      [attachment=1:6l2q4qpb]<!-- ia1 -->Capture.PNG<!-- ia1 -->[/attachment:6l2q4qpb]
                      Hey all,
                      Sounds like you extracted the content of TT_Lib directly in the plugins folder istead of preserving the TT_Lib2 that contains them.
                        Mra
                        thomthom, sweet script. However i'm having problems with one of your tools.
                        The "Split faces into multiple pieces" doesn't seem to work properly on this face;
                        http://i.imgur.com/At0My.jpg
                        I can't give you the full scene though (NDA) and when I just paste this piece into a new sketchup scene your tool works. Any ideas? πŸ˜„
                        Exploding object doesn't work either. The axis is at default place in the world at 0,0,0.
                          Can you save a copy of the model - erasing everything else - purge the model, then send it to me?
                            Mra
                            Hi Thomthom, today is another day, so after I turn on the computer again, it seems there is no problem on the same piece of mesh anymore. Something must've been corrected when restarting SketchUp. Perhaps I ran into a bug by somehow? But anyway, thanks for your offer to take a look. If it ever happens again, I will try and get some reproducible steps.
                              Ghost in the box. πŸ˜„
                              • E
                                ErikLiu0801
                                thanks a lot.
                                i'm not good at english but i still want to say thanks for your sharing.
                                • bobpineoB
                                  bobpineo
                                  Thomthom,
                                  Using this plugin again today on another very large autocad import, can't tell you how grateful I am for your plugin!
                                  Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                    πŸ˜„
                                    • G
                                      gina
                                      HELP !
                                      It doesnt work for me. i'm using su 8, and at the beginning of load screen a message box appear saying that theres an error from loading the edges tool plugins.
                                        What is the exact error message?
                                          As Dave said, without knowing the error it's impossible to determine what the problem is.
                                          If I'd hazard a guess, did you install the required TT_Lib2? Linked under Requirements right above the Download button?
                                          • onzkiO
                                            onzki
                                            This is an amazing tool. Thanks so much it's very useful. I like the concept of curve simplification.. However, forgive my out of the world request, is it also possible to have a way to make curves smoother- meaning an option to add segments rather than reduce. I know it sounds crazy but there are times when most of my CAD import are roughly segmented like the one shown on screenshot.
                                            http://img837.imageshack.us/img837/3300/roughlysegmented.jpg
                                            [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                            • 11
                                            • 8 / 11
