    [Plugin] Heightmap from model
    63 Posts 28 Posters 62.5k Views 29 Watching
    • N Offline
      notareal
      👍 Nice tool. Wonder if hdr or exr would be possible as file options.
      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
      • TIGT Online
        @didier bur said:
        It seems that crappy Vista is causing the problem (as usual).
        Since the script writes binary BMP or RAW files, ensure you have the right to do this (be logged as admin ?)
        Any other clue anyone ?
        Where does it write these to?
        I am an admin so it shouldn't matter.
        Also it crashes SUp BEFORE you try to do anything - just by loading it you get the problem.
        • charly2008C Offline
          charly2008
          Hi TIG,
          i have the same problem with XP. SU7 was just by loading and then came a Bugsplat.
          Karlheinz
          • Didier BurD Offline
            Didier Bur
            It writes images at the same location than the SKP is.
            That's what is really strange. I don't overwrite built-in methods, don't do any 'require' or something that involve other files.
            Would you please test this version and tell me if the problem persists ? 🎉
            mesh2HeightMap.zip
            DB
            • PixeroP Offline
              Pixero
              Still crashes instantly while loading SU. Now on Windows 7 64bit. SU 7.1.
                charly2008
                it still crashes while loading SU.
                Karlheinz
                • TIGT Online
                  Test file = instant Bugsplat.
                  Didier - why not PM or email the 'uncompiled' script to one of us for debugging - you can trust me 😉 ...
                  You know that I hack into your encrypted rb files all of the time, but the rbs ones are a bit harder... just easier if you supply it unencrypted...
                  It must be simple to fix...
                  • G Offline
                    georglorenz
                    Slightly off topic here: Is there a plugin that does the exact opposite of this one? That is creating a terrain from an greyscale image (.jpg or anything else)? Thank you. G
                    • Chris FullmerC Offline
                      There is, Didier wrote a script that imports a heightmap image into SU. I forget what its called, but it was written by didier bur and should be posted here on the forum somewhere....
                      Chris
                      All my Plugins I've written
                      • N Offline
                        notareal
                        Nice work!
                          miikka1978
                          Did anybody find some solution for instant BugSplat upon starting SU when using this plugin?
                            I was going to look at the code, but it is encrypted. So it would require Didier to look at it.
                            Sometimes if the script calls the active_model before the model is initialized by SU it can cause problems. But I can't see if the script is possibly doing anything like that.
                              miikka1978
                              Chris,
                              Is it possible to use your Color by Z- plugin for creating a heightmap from model? I would need to create heightmap from Sketchup model and take it into Unity 3D for creating a terrain (just like Heightmap plugin was supposed to do).
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=16660
                                Look at the technicque used in this post:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=16660&start=15#p131738
                                The idea is to make your terrain, then apply a gradient image to the entire terrain. It will make a much smoother gradient than my color by Z and the gradient will be more accurate.
                                You can try using the attached gradient image. That will give you a greyscale heightmap. I don't know what file format you need, but I am hoping you can export a black and white image from SU and find a way to get it into the correct format.
                                Let me know if this works, if you are still missing a piece to the puzzle.
                                Chris
                                  ohh, hmm. I think perhaps this does something different than I thought. What are you trying to achieve? You already have a greyscale terrain and want to turn it into 3d geometry? If so, that is very different than what my color by z does. It would not be able to be tweaked to do that.
                                    Didier Bur
                                    Hi all,
                                    A new version of the script has been uploaded May 5th 2010 (no more instant bugsplat).
                                    Find it here: http://forums.sketchucation.com/viewtopic.php?p=209935#p209935
                                    The scrambler still puzzles me...
                                    DB
                                    • TIGT Online
                                      Thanks, now working perfectly... 😄
                                        miikka1978
                                        Thank you Didier!
                                          morrowsend1
                                          This is a great plugin!
                                          I'd love to be able to customize this code for use with a project I am working on. Any chance you will be releasing the code?
                                          Things that would GREATLY help my project include:
                                          • Making Black a background color
                                          • Making square output images (my heightmap importer only accepts square images.)
                                          • The ability to scale the output images to any size I need.
                                            dbalex
                                            really impressive plugin, very nice for render purposes!
                                            But could it be possible to enable it also in perspective view so we could have a depth map for postprocessing a sketchupview?
                                            anyway, thank you very much for this plugin didier!
                                            http://www.bocostudio.com
                                            • 2 / 4
