    [Plugin] Heightmap from model
    63 Posts 28 Posters 69.4k Views 29 Watching
    • EarthMoverE
      EarthMover
      Didier I extracted the plugin to the plugins folder and it causes SU to crash upon opening. I removed the plugin and SU opened fine.
      Content Creator at Skapeup
      • Didier BurD
        Didier Bur
        It seems that crappy Vista is causing the problem (as usual).
        Since the script writes binary BMP or RAW files, ensure you have the right to do this (be logged as admin ?)
        Any other clue anyone ?
        DB
        • PixeroP
          Pixero
          Well...I had the same problems on XP at work, so... it can't be just Vista.
          • N
            notareal
            👍 Nice tool. Wonder if hdr or exr would be possible as file options.
              Where does it write these to?
              I am an admin so it shouldn't matter.
              Also it crashes SUp BEFORE you try to do anything - just by loading it you get the problem.
              • charly2008C
                charly2008
                Hi TIG,
                i have the same problem with XP. SU7 was just by loading and then came a Bugsplat.
                Karlheinz
                • Didier BurD
                  Didier Bur
                  It writes images at the same location than the SKP is.
                  That's what is really strange. I don't overwrite built-in methods, don't do any 'require' or something that involve other files.
                  Would you please test this version and tell me if the problem persists ? 🎉
                  mesh2HeightMap.zip
                  DB
                  • PixeroP
                    Pixero
                    Still crashes instantly while loading SU. Now on Windows 7 64bit. SU 7.1.
                    • charly2008C
                      charly2008
                      it still crashes while loading SU.
                      Karlheinz
                        Test file = instant Bugsplat.
                        Didier - why not PM or email the 'uncompiled' script to one of us for debugging - you can trust me 😉 ...
                        You know that I hack into your encrypted rb files all of the time, but the rbs ones are a bit harder... just easier if you supply it unencrypted...
                        It must be simple to fix...
                        • G
                          georglorenz
                          Slightly off topic here: Is there a plugin that does the exact opposite of this one? That is creating a terrain from an greyscale image (.jpg or anything else)? Thank you. G
                          • Chris FullmerC
                            There is, Didier wrote a script that imports a heightmap image into SU. I forget what its called, but it was written by didier bur and should be posted here on the forum somewhere....
                            • N
                              notareal
                              Nice work!
                                miikka1978
                                Did anybody find some solution for instant BugSplat upon starting SU when using this plugin?
                                • Chris FullmerC
                                  I was going to look at the code, but it is encrypted. So it would require Didier to look at it.
                                  Sometimes if the script calls the active_model before the model is initialized by SU it can cause problems. But I can't see if the script is possibly doing anything like that.
                                    miikka1978
                                    Chris,
                                    Is it possible to use your Color by Z- plugin for creating a heightmap from model? I would need to create heightmap from Sketchup model and take it into Unity 3D for creating a terrain (just like Heightmap plugin was supposed to do).
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=16660
                                    • Chris FullmerC
                                      Look at the technicque used in this post:
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      The idea is to make your terrain, then apply a gradient image to the entire terrain. It will make a much smoother gradient than my color by Z and the gradient will be more accurate.
                                      You can try using the attached gradient image. That will give you a greyscale heightmap. I don't know what file format you need, but I am hoping you can export a black and white image from SU and find a way to get it into the correct format.
                                      Let me know if this works, if you are still missing a piece to the puzzle.
                                      • Chris FullmerC
                                        ohh, hmm. I think perhaps this does something different than I thought. What are you trying to achieve? You already have a greyscale terrain and want to turn it into 3d geometry? If so, that is very different than what my color by z does. It would not be able to be tweaked to do that.
                                        • Didier BurD
                                          Didier Bur
                                          Hi all,
                                          A new version of the script has been uploaded May 5th 2010 (no more instant bugsplat).
                                          Find it here: http://forums.sketchucation.com/viewtopic.php?p=209935#p209935
                                          The scrambler still puzzles me...
                                          DB
                                            Thanks, now working perfectly... 😄
                                            • 2 / 4
