    [Plugin] Heightmap from model
    63 Posts 28 Posters 64.2k Views 29 Watching
      Test file = instant Bugsplat.
      Didier - why not PM or email the 'uncompiled' script to one of us for debugging - you can trust me πŸ˜‰ ...
      You know that I hack into your encrypted rb files all of the time, but the rbs ones are a bit harder... just easier if you supply it unencrypted...
      It must be simple to fix...
        georglorenz
        Slightly off topic here: Is there a plugin that does the exact opposite of this one? That is creating a terrain from an greyscale image (.jpg or anything else)? Thank you. G
        • Chris FullmerC Offline
          There is, Didier wrote a script that imports a heightmap image into SU. I forget what its called, but it was written by didier bur and should be posted here on the forum somewhere....
          • N Offline
            notareal
            Nice work!
              miikka1978
              Did anybody find some solution for instant BugSplat upon starting SU when using this plugin?
                I was going to look at the code, but it is encrypted. So it would require Didier to look at it.
                Sometimes if the script calls the active_model before the model is initialized by SU it can cause problems. But I can't see if the script is possibly doing anything like that.
                  miikka1978
                  Chris,
                  Is it possible to use your Color by Z- plugin for creating a heightmap from model? I would need to create heightmap from Sketchup model and take it into Unity 3D for creating a terrain (just like Heightmap plugin was supposed to do).
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=16660
                    Look at the technicque used in this post:
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=16660&start=15#p131738
                    The idea is to make your terrain, then apply a gradient image to the entire terrain. It will make a much smoother gradient than my color by Z and the gradient will be more accurate.
                    You can try using the attached gradient image. That will give you a greyscale heightmap. I don't know what file format you need, but I am hoping you can export a black and white image from SU and find a way to get it into the correct format.
                    Let me know if this works, if you are still missing a piece to the puzzle.
                      ohh, hmm. I think perhaps this does something different than I thought. What are you trying to achieve? You already have a greyscale terrain and want to turn it into 3d geometry? If so, that is very different than what my color by z does. It would not be able to be tweaked to do that.
                      • Didier BurD Offline
                        Didier Bur
                        Hi all,
                        A new version of the script has been uploaded May 5th 2010 (no more instant bugsplat).
                        Find it here: http://forums.sketchucation.com/viewtopic.php?p=209935#p209935
                        The scrambler still puzzles me...
                        DB
                          Thanks, now working perfectly... πŸ˜„
                            miikka1978
                            Thank you Didier!
                              morrowsend1
                              This is a great plugin!
                              I'd love to be able to customize this code for use with a project I am working on. Any chance you will be releasing the code?
                              Things that would GREATLY help my project include:
                              • Making Black a background color
                              • Making square output images (my heightmap importer only accepts square images.)
                              • The ability to scale the output images to any size I need.
                                dbalex
                                really impressive plugin, very nice for render purposes!
                                But could it be possible to enable it also in perspective view so we could have a depth map for postprocessing a sketchupview?
                                anyway, thank you very much for this plugin didier!
                                http://www.bocostudio.com
                                • jason_marantoJ Offline
                                  jason_maranto
                                  This is indeed very useful for rendering purposes πŸ˜„ -- I would second the idea that being able to generate the image at whatever resolution needed would be great.
                                  In regards to the previous post, you can do a quick version of what you want using fog:
                                  Best,
                                  Jason.
                                    dbalex
                                    Interesting way jason_maranto, thanks for that, will try it!
                                    • H Offline
                                      Hanstania
                                      Hey Didier! Trying to get google terrain into UDK and tought this plugin was just what i needed. Got a problem though.
                                      First off, 18700016 rays to shoot? Thats a bit much, why does that number get so large? The model is just a small section of terrain.
                                      After the export when i open the raw file in Photoshop it does not show up as heightmap, but more like a grey mess.
                                      Any suggestions? I've got the plane version of sketchup pro and your plugin is the only one installed. Do i need additional plugins installed or something?
                                      Pardon my noobiness!
                                      Cheers!
                                        Didier Bur
                                        Hi Hanstania,
                                        What this plugin does is the inverse of thomthom's 'Bitmap to mesh' here: http://forums.sketchucation.com/viewtopic.php?t=31339
                                        As you can see a heightmap is a grey scale image so you'll get a greyscale image with my plugin. The size (in pixels) of this image is basically the size of your SU viewport. 18700016 rays to shoot is the result of width_of_your viewport * height_of_your viewport. For instance, a 1024*768 viewport will give 786432 rays and 786432 pixels in the calculated heightmap.
                                        You can resize down your viewport or lower your screen resolution to get smaller (but less accurate) images.
                                        Ensure to 'zoom-extents' your terrain in a top-down orthographic view before launching the script.
                                        You don't need to install anything else that the script.
                                        Please post an example of the 'grey mess' you got πŸ˜‰
                                        Below are 2 images of a GE captured terrain (mountain and sea) and the resulting heightmap on a red mask. It took 6 minutes to process.
                                        DB
                                        • H Offline
                                          Hanstania
                                          I got it to work properly. I wasn't paying enough attention to formats/image sizes and what not. Oops.
                                          Thanks anyway Didier and thanks alot for this plugin, it's been extremely helpful when recreating realworld locations.
                                            aile009
                                            @didier bur said:
                                            Hi all,
                                            After a long silence, here is another toy I wrote to export SU terrains to Unity3D game engine, which uses RAW heightmaps to create terrains. I thought it could be of any interest to others, so here it is.
                                            Features:
                                            • creates BMP or RAW images, greyscale or color, 8 bits or 16 bits from any view of your model (top view recommanded of course)
                                            • creates a colored mask where no faces found in the view
                                            • can crop the image to the model projection
                                            • can blur the heightmap before writing it.
                                            Extract in Plugins folder, PDF doc included.
                                            Regards,
                                            EDIT: new release May 5th 2010, instant bugsplat fix πŸ˜›
                                            hi, i'm using heightmap from model plugin, and have got the heightmap. but i don't know the minimum and maximum elevation of the mode. Does the plugin provide these values? Without these values i can't generate a accurate terrain in other 3D software.
                                            • 2 / 4
