    "Tell me what's goin' on. I ain't got a clue!"
    28 Posts 6 Posters 2.7k Views 6 Watching
    • M
      MartinRinehart
      I've created a Rectangle class, approximately the Rectangle tool in code. Unlike the tool, it promises to provide, for orthogonal rectangles, a rectangle that faces the positive direction of the perpendicular axis. Here is the draw code:
          def draw()
              model=Sketchup.active_model()
              ents = model.entities()
              @group = ents.add_group()
              corners = get_corners()
              @face = @group.entities().add_face(
                  corners[0], corners[1], corners[2], corners[3] )
              face.reverse!() unless @plane == 'rb'
              model.selection.add( @group )
          end # of draw()
          def get_corners()
              r = 0; g = 1; b = 2;
              ret = []
              ret[0] = @near
              ret[2] = @far
              if ( plane == 'rg' ) || ( plane == 'no' )
                  ret[1] = [ @near[r], @far[g], @far[b] ]
                  ret[3] = [ @far[r], @near[g], @near[b] ]
              elsif plane == 'gb'
                  ret[1] = [ @near[r], @near[g], @far[b] ]
                  ret[3] = [ @near[r], @far[g], @near[b] ]
              else # plane == 'rb'
                  ret[1] = [ @near[r], @near[g] ,@far[b] ]
              return ret
          end # get_corners()
      This line is the one I don't understand:
      I put that in because by trial and error I find it works. I don't like to code by trial and error. I'm happy when I understand reasons. Can someone explain why?
      Thanks.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • TIGT
        Haven't tried it, but your get_corners always returns ret as the the last test because the other test possibilities are never met - plane is never defined so it's always nil and can never == the strings' '' values...
        says reverse the face unless the @plane is 'rb'
        BUT since @plane is not defined anywhere it's always nil, so it can't == 'rb' - so the face isn't reversed ?
        You need to define @plane somewhere to test it, and get_corners needs to test some actual possibilities...
        πŸ€“
        • M
          MartinRinehart
          Sorry TIG. This is working code in a working class. @plane is created in the constructor. It's one of 'rb', 'gb', 'gr' or 'no' (Not Orthogonal). My question is why every face I create needs to be reversed, unless it's in the 'rb' plane. Let me put it another way.
          Why do I care that the normal points to the positive end of the perpendicular axis? This is the foundation of the box class, among others. The box class commits to having a positive pushpull value pushpull in the positive direction.
          • thomthomT
            You have to reverse the face when you create it on the Red-Green plane?
            That's SU'd famous exception to face-creation. When you make a face on the ground it flips the front face down regardless. Though, I think it only does that on level 0 (z==0). Do you see this behaviour on other levels?
            • TIGT
              As TT says if you make faces and the points are ordered appropriately the normal is fixed as you expect... EXCEPT if Z=0 and the face is flat in the XY plane then the face will always have normal.z=-1 no matter what you have set it to be - It's a SUp built-in foilble - draw a Rectangle anywhere and the normal in fixed sensibly - BUT if it's on the ground plane the normal will face down no matter what you do...
              So check for flat faces where Z=0 and ALWAYS flip them if you want normal.z=+1...
              • M
                MartinRinehart
                What you guys are saying and what I'm seeing are not the same. I'm flipping faces in two of the three planes. And I'm flipping regardless of the z value.
                Here 'r' creates a rectangle instance.
                # /r/rects.rb
                rec1 = r [0,0,10], [20,20,10]
                rec2 = r [10,0,0], [10,20,10]
                rec3 = r [0,10,0], [20,10,10]
                This is the result:
                I've got three faces, outsides all facing the positive direction. rb was not flipped. The other two, rg (z == 10) and bg were flipped. (SU 7.1, PC).
                • J
                  Jim
                  Because the order of the vertices matters when creating a face? (with the possible exception when drawing on the rg plane at z=0.)
                  swapping verts 2 and 4 (index 1 and 3) might reverse the normal.
                  • M
                    MartinRinehart
                    I gave that a really quick try and didn't see a difference.
                    • J
                      Jim
                      Hmm. Just throwing things out if anything sticks.
                      TIG's right about the plane variable. It is a variable local to the get_corners method, and is never defined in get_corners before use. You will get an undefined variable exception if you try to run the code. If you are not getting an exceprion, you have another problem.
                      What does "positive" mean in this context? Ruby pushpull uses the face normal as "positive", no matter its orientation globally or in the Group context.
                      If you draw a face with a normal in the same direction as an Axis, then pushpull the face in the positive direction, the face is going to reverse automatically.
                      Edit - I'll generalize that last statement to: a face pushpulled in its positive direction (its own normal direction) will reverse.
                      • M
                        MartinRinehart
                        Oh dear. Should have been "@plane". Now my question is, why does it work as written?
                        Toward the positive end of the perpendicular axis.
                        • M
                          MartinRinehart
                          No more question, except maybe, "Why could we all be so foolish?"
                          From the constructor:
                          attr_reader ... ;plane, ...
                          @plane = ...
                          It's not a local variable, it's a method call. This is Ruby.
                          • TIGT
                            If you haven't defined 'plane' then it's taken to be nil, so the test is if nil==something if something is also nil then it's true !!! πŸ˜’
                            • TIGT
                              How were we meant to know that you had defined 'plane' as a method, let alone a variable - which it seemed it might be at first glance, there were no clues in your published code ???
                              If you publish half of the story you'll get a lot more 'answers' than you need... ❓
                              • M
                                MartinRinehart
                                TIG, plane is defined. attr_reader ... :plane ... is equivalent to
                                def plane()
                                    return @plane
                                edit: and this being Ruby plane is also plane() - maybe not Matz's best decision as this discussion shows.
                                All of which is to say I've got good working code that produces faces facing the positive end of the perpendicular axis and it does this by reverse!() for everything not in the 'rb' plane and I've no clue why and the standard answer "SU draws upside down in the rg plane when z=0" is true but it's not an answer to my question.
                                • M
                                  MartinRinehart
                                  My apologies.
                                  • J
                                    Jim
                                    So, what does the plane() method look like?
                                    • thomthomT
                                      There is none. He used attr_reader(:plane) which is the same as:
                                      def plane()
                                        return @plane
                                      • J
                                        Jim
                                        Yes, well, I see that now. 😳 So it's just a string anyway.
                                        • TIGT
                                          Seems this is making it all too complicated for its own good πŸ˜‰
                                          What's wrong with testing @plane directly ?
                                          • J
                                            Jim
                                            There is no doubt of that.
                                            • 1 / 2
