    "Tell me what's goin' on. I ain't got a clue!"
    28 Posts 6 Posters 2.4k Views 6 Watching
      MartinRinehart
      @tig said:
      Haven't tried it, but
      Sorry TIG. This is working code in a working class. @plane is created in the constructor. It's one of 'rb', 'gb', 'gr' or 'no' (Not Orthogonal). My question is why every face I create needs to be reversed, unless it's in the 'rb' plane. Let me put it another way.
      Why do I care that the normal points to the positive end of the perpendicular axis? This is the foundation of the box class, among others. The box class commits to having a positive pushpull value pushpull in the positive direction.
        You have to reverse the face when you create it on the Red-Green plane?
        That's SU'd famous exception to face-creation. When you make a face on the ground it flips the front face down regardless. Though, I think it only does that on level 0 (z==0). Do you see this behaviour on other levels?
          As TT says if you make faces and the points are ordered appropriately the normal is fixed as you expect... EXCEPT if Z=0 and the face is flat in the XY plane then the face will always have normal.z=-1 no matter what you have set it to be - It's a SUp built-in foilble - draw a Rectangle anywhere and the normal in fixed sensibly - BUT if it's on the ground plane the normal will face down no matter what you do...
          So check for flat faces where Z=0 and ALWAYS flip them if you want normal.z=+1...
            MartinRinehart
            What you guys are saying and what I'm seeing are not the same. I'm flipping faces in two of the three planes. And I'm flipping regardless of the z value.
            Here 'r' creates a rectangle instance.
            # /r/rects.rb
            rec1 = r [0,0,10], [20,20,10]
            rec2 = r [10,0,0], [10,20,10]
            rec3 = r [0,10,0], [20,10,10]
            This is the result:
            I've got three faces, outsides all facing the positive direction. rb was not flipped. The other two, rg (z == 10) and bg were flipped. (SU 7.1, PC).
              Jim
              Because the order of the vertices matters when creating a face? (with the possible exception when drawing on the rg plane at z=0.)
              swapping verts 2 and 4 (index 1 and 3) might reverse the normal.
                MartinRinehart
                I gave that a really quick try and didn't see a difference.
                  Jim
                  Hmm. Just throwing things out if anything sticks.
                  TIG's right about the plane variable. It is a variable local to the get_corners method, and is never defined in get_corners before use. You will get an undefined variable exception if you try to run the code. If you are not getting an exceprion, you have another problem.
                  What does "positive" mean in this context? Ruby pushpull uses the face normal as "positive", no matter its orientation globally or in the Group context.
                  If you draw a face with a normal in the same direction as an Axis, then pushpull the face in the positive direction, the face is going to reverse automatically.
                  Edit - I'll generalize that last statement to: a face pushpulled in its positive direction (its own normal direction) will reverse.
                    MartinRinehart
                    Oh dear. Should have been "@plane". Now my question is, why does it work as written?
                    Toward the positive end of the perpendicular axis.
                      MartinRinehart
                      No more question, except maybe, "Why could we all be so foolish?"
                      From the constructor:
                      attr_reader ... ;plane, ...
                      @plane = ...
                      It's not a local variable, it's a method call. This is Ruby.
                        If you haven't defined 'plane' then it's taken to be nil, so the test is if nil==something if something is also nil then it's true !!! πŸ˜’
                          How were we meant to know that you had defined 'plane' as a method, let alone a variable - which it seemed it might be at first glance, there were no clues in your published code ???
                          If you publish half of the story you'll get a lot more 'answers' than you need... ❓
                            MartinRinehart
                            TIG, plane is defined. attr_reader ... :plane ... is equivalent to
                            def plane()
                                return @plane
                            edit: and this being Ruby plane is also plane() - maybe not Matz's best decision as this discussion shows.
                            All of which is to say I've got good working code that produces faces facing the positive end of the perpendicular axis and it does this by reverse!() for everything not in the 'rb' plane and I've no clue why and the standard answer "SU draws upside down in the rg plane when z=0" is true but it's not an answer to my question.
                              MartinRinehart
                              My apologies.
                                Jim
                                So, what does the plane() method look like?
                                  There is none. He used attr_reader(:plane) which is the same as:
                                  def plane()
                                    return @plane
                                    Jim
                                    Yes, well, I see that now. 😳 So it's just a string anyway.
                                      Seems this is making it all too complicated for its own good πŸ˜‰
                                      What's wrong with testing @plane directly ?
                                        Jim
                                        There is no doubt of that.
                                          No - it's nothing. it's nil until a value is assigned. it just makes the instance variable available to the outside scope.
                                          but in the context of Martin's code - yes @plane is a string.
                                            Jim
                                            I was looking back at the original code and just skimmed over the later post. Even so, there is still no clue to what type of object @plane refers since the actual assignment is not given.
