    "Tell me what's goin' on. I ain't got a clue!"
    28 Posts 6 Posters 2.7k Views 6 Watching
    • thomthomT
      @jim said:
      Yes, well, I see that now. 😳 So it's just a string anyway.
      No - it's nothing. it's nil until a value is assigned. it just makes the instance variable available to the outside scope.
      but in the context of Martin's code - yes @plane is a string.
      • J
        Jim
        I was looking back at the original code and just skimmed over the later post. Even so, there is still no clue to what type of object @plane refers since the actual assignment is not given.
        • C
          cjthompson
          this is a bit off topic, but I was just curious: how would you handle a rectangle that has a normal of (1,1,-1) or something similar?
          • M
            MartinRinehart
            @tig said:
            What's wrong with testing @plane directly ?
            That would be best. I forgot the "@" - simple coding goof - but the test got done, the program worked, so I didn't notice.
            Would have been better if method calls needed parens so you a) see that it's a method call, b) get a compile-time error for forgetting the "@" and c) fix your simple mistake, instead of publishing it.
            But back to the original topic. If you draw your points clockwise ... What's clockwise?
            Clockwise above is origin, up blue axis, out on rg plane, right?
            Clockwise is origin, out on rg plane, up blue axis, right?
            Note that both shots are of the same model, with a wee bit of orbiting to change point of view. Ergo, an unqualified "clockwise" is meaningless.
            A bit off topic, the title is Jimmy Buffett in "Everybody's Got a Cousin in Miami" paraphrasing Jimmy Buffett in "Margaritaville." It accurately describes my knowledge re normals after a face is drawn.
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
            • Chris FullmerC
              Clcokwise is where the face's normal is pointing directly back at "you" when "you" draw it. So orientation within the model is meaningless.
              All my Plugins I've written
              • TIGT
                The 'right-hand' rule: you grasp the normal axis [above the face] in your right-hand with your thumb pointing in the positive direction.
                Your fingers will curl in the counter-clockwise direction.
                The 'left-hand' rule is the reverse of this...
                When you return an array of a face's vertices they are always listed counter-clockwise... right-hand rule... β˜€
                • M
                  MartinRinehart
                  Could you explain this little bit, in small words? Thx.
                  Does "above" mean on the side of the normal? How can I control which side is "above"? Thx.
                  • TIGT
                    'Above' in this context is on the side of the face's front.
                    If the face is flat and it were facing upwards your hand would be above it.
                    The that face were facing downwards then your hand would be underneath it...
                    • 2 / 2
