    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 231.3k Views 51 Watching
      trimguy66
      Thank you gentlemen, found it, I was looking in Plugins.
      This is a great tool, and a great forum.
      Thanks again!!
      Wayne
      • guanjinG Offline
        guanjin
        V 0.3.1 version, did not see
        I come from China, is to learn
          Really? Where were you looking?
          πŸ˜’
          • designerbursaD Offline
            designerbursa
            thank you
              samyell77
              Anyone getting bugsplats with this plugin? Love it and find it very useful but for some reason it is buggin out constantly on me - doesn't work at all! Can anyone help.....?
              Version numbers below... even tried downloading the current french version but no joy. Tried copying some parts out of my model into a fresh model and still got the bugsplat!
              Eclate Deplace - Version 0.3.2 rewritted by Fredo
              Radial Move - Version 0.3.2 rewritted by Fredo
              SU Pro 2016
              Dell Precision M4800
              PC Windows 10
              Intel Core i7-4900MQ @ 2.80ghz
              Nvidia Quadro K2100M
              16gb RAM
                samyell77
                Anyone??? Or is it just me...
                Can't get this to work at all for some reason, just crashes every time I try to use it.
                Any help or suggestions very gladly received πŸ˜„
                SU Pro 2016
                PC Windows 10
                16gb RAM
                  I just downloaded and installed it and it works for me on SU2013. Perhaps you have some other plugin that is causing the conflict. Do you have the Vray or Podium plugins? You might try disabling other plugins and see if this one will run for you.
                    samyell77
                    Thanks DaveR, will try disabling some plugins and see. Hadn't thought of that - DOH!
                    SU Pro 2016
                    PC Windows 10
                    16gb RAM
                      SketchyPhysics is also a big pertubator! πŸ˜‰
                        samyell77
                        Hi All,
                        Have tried to disable everything except Eclate Deplace and it STILL crashes? Anyone got any thoughts. Im stumped and seeing as I use this plugin almost daily am pulling my hair out.
                        Any help greatly appreciated as always....
                        Not sure what other plugins need to run with Eclate Deplace so not sure if there is anythign that has to be on to allow it to work.
                        Sam
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                        • BoxB Offline
                          Perhaps there is something wrong with the model, or does it happen with all?
                            samyell77
                            Yes - tried to draw 3 boxes in a new model and run the plugin and it crashed?
                            Stumped....
                            SU Pro 2016
                            PC Windows 10
                            16gb RAM
                            • BoxB Offline
                              Just tested and it's working fine here on 7,8 and 13.
                              Have you changed anything recently, graphic card/driver, windows version/update , any new hardware..etc etc... you might need to track back to what you did before it started to crash.
                                samyell77
                                Installed a new graphics card recently but a colleague of mine has the same machine and had the same card installed at the same time and no problems.
                                Have removed all plugins from my plugins folder and installed only eclate deplace and still getting crashes every time... Arrrrrgh!
                                Going to have to make exploded diagrams manually for now.....
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                • BoxB Offline
                                  Have you tried changing the opengl settings, sometimes just turning hardware acceleration off or on fixes things and it can often be switched back after.
                                    samyell77
                                    Thanks Box - tried and no joy Im afraid. Think its an issue with a graphics card. Going to sort it next week some time (hopefully)...
                                    Cheers
                                    Sam
                                    SU Pro 2016
                                    PC Windows 10
                                    16gb RAM
                                      samyell77
                                      Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                        Maybe you can also try to run it with it alone inside the Plugins folder for see if there is no compatibility with an another plugin!
                                          It has been a know problem with SketchUp that having the Outliner open and 'rolled-down' when running ANY processes that require intensive/multiple creation/changes to groups/components... it can at least significantly slow down the processing, and at worst cause a full crash/splat.
                                          So the simple rule is when doing this kind of intensive processing, do not have the Outliner open, or if it is open, then do not have it 'rolled-down'.
                                          And of course always save your work before starting any really complex operations that might lead to a failure/crash...
                                            samyell77
                                            Hi TIG, Pilou,
                                            Thanks - had come around to that conclusion but thanks for confirming. Pilou, with outlier closed I have had no crashes and don't seem to have to run radial move first to get Eclate Deplace to work. As TIG says from now on I'll make sure I have the outliner window shut when doing anything with Eclate Deplace.
                                            Thanks again for your help and Pilou thanks for a great plugin - I use it all the time and its a massive time saver for me...! πŸ‘
                                            SU Pro 2016
                                            PC Windows 10
                                            16gb RAM
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
