    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 227.5k Views 51 Watching
    • BoxB Offline
      I'm using the latest version of sketchup and I get a bug splat every time I try to use Eclate.
      Even with a simple cube. As soon as you click yes or no on the copy dialog it shuts down and goes to bug splat.
        c.plassais
        you should only use Eclate_Deplace with components or groups
        • K Offline
          kyyu
          Anyone experiencing Bugsplats with SU7.1 and this plugin?
          Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
          I know i have the components nested in a component but use this plugin when not nested
          It doesn't bug splat for me, but I am still using SU v7.0.10247. It doesn't do much with that file either, except add one guide point?
          I tried it on an ungrouped 3D pushpulled rectangle and also not bug splat. So could be something not compatable with the latest version of sketchup.
            @kyyu said:
            ... It doesn't do much with that file either, except add one guide point?
            Why would you use it on an "ungrouped 3D push/pulled rectangle"? The plugin is intended to move components away from each other to create an exploded view of this sort.
            http://farm5.static.flickr.com/4023/4628792635_15716dcc29.jpg
            • K Offline
              kyyu
              Because a few post up, Box said he was getting bug splats on everything; even with a simple cube. So I tested it, but maybe he meant a cube made of grouped sides? Anyways, I was checking for bug splats and didn't find any. But, like I noted, I'm using v7.0 of sketchup.
              • BoxB Offline
                Yes I was using a cube of grouped faces, and at first I was getting a bug spat every time, now it is random.
                I have rebooted and added updates and a few other bits and pieces since then, sorry that's not a very useful bit of diagnostic information but I've been doing too many things at once.
                So to put it simply, It does work for me but it is unstable and I have yet to work out what, if any, conditions cause the bug splat.
                  c.plassais
                  Two versions of the plugin that can be corrected bug
                  I've written a 3.0.2 version and also a rewritten version by the genius Fredo. Thanks Fredo ๐Ÿ‘
                  Sorry I can not insert in the original post ...
                  The limitation of this plugin is that it does not take into account the size of groups or components.
                  It moves only the elements from their center. Perhaps a future version
                  Christophe
                  Eclate_Deplace english version 3.0.2
                  version 3.0.2 rewritten by fredo ChrisP_RadialMove
                    Added to the first post ๐Ÿ˜‰
                      c.plassais
                      Thank Pilou ๐Ÿ‘
                        dedmin
                        • V Offline
                          vidy
                          dear guys,
                          is there any possibility of this plugin have crashed with other plugin?
                          ok, here is what i did:
                          1. i copy the newest version 3.0.2
                          2. then rename it so its just Eclate_Deplace.rb
                          3. i create simple cube, and then group it
                          4. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                          http://a.imageshack.us/img829/1341/eclatedeplaceprob01.jpg
                          please,somebody help me to solved this issue, thank you.. โ“
                          regards,
                          still so much to learn..
                            Finally it's back working ๐Ÿ‘
                            Thanks Pilou....C.Plassais....TIG....Thomthom....Chris Fullmer....Fredo!
                            Hope i left no one out?
                              Maybe cats and dogs and birds...
                              It's a big familly ๐Ÿ˜†
                                About
                                Facegroup by Gavvy (seems there a is little problem with this facegroup plugin) Thomthom is look it! and seems found the error โ˜€
                                And I have found another one who works ๐Ÿ˜‰
                                Make_components by Matt666 at Crai Ruby depot!
                                And a third solution by Tig! (face selected ---> groups)
                                Put this in the Ruby console! โ˜€
                                m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                                • V Offline
                                  vidy
                                  thanks pilou for the fast reply, i will try it and report it soon..
                                  regards,
                                    With newest version 3.0.2
                                    I don't believe that
                                    1. i create simple cube, and then group it
                                    2. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                                    Normal : a simple cube must be composed of a 6 faces themself a group!!!
                                    (so for a cube: 6 faces who are each a group) !
                                    in this image i have selected one face for you show that is a group
                                    (each face is a group)
                                    Select them then call the plug!
                                    If you want transform automatically each 6 faces of a simple cube on 6 groups maybe exist a plug ๐Ÿ˜‰
                                    (or any faces selected)
                                    Facegroup by Gavvy (seems there a little problem with this facegroup plugin) Thomthom is look it!
                                    Make_components by Matt666 at Crai Ruby depot! โ˜€
                                    Ps Menu of "Radial Move" or "Eclate_displace" Appear by Right Click on the selection of the groups or components!
                                    • Y Offline
                                      yvan79
                                      How do you use the ChrisP_RadialMove_EN.rb plugin? can anyone show an example?
                                        No problem ๐Ÿ˜„
                                          I don't see your images ๐Ÿ˜ฎ
                                          Verify that your object is composed of groups or components!!!
                                          A simple cube grouped will not works if each face is not a group!!!
                                          • Y Offline
                                            yvan79
                                            Hi pilou...thanks for the instructions but i have an error of saying 'No effective transformation - nothing has been created'.
                                            • 8
                                            • 9
                                            • 3 / 9
