    Component copy along a circle??
    13 Posts 5 Posters 3.3k Views 5 Watching
    • charly2008C
      charly2008
      Hi to All,
      need help! I would like to copy a component along a polygon as shown below. I tried "copy along path" but didn't get the wanted result. Is there a ruby which can do that?
      Karlheinz
        Would Copy Array using Rotate Tool work for you?
        • charly2008C
          charly2008
          Hi rclub24,
          At the moment I can not remember how I can perform this function!
          Karlheinz
            Same as the way you copy using the Move Tool
            [flash=853,505:2xv312yj]http://www.youtube.com/v/CRjnlPRG6rU[/flash:2xv312yj]
              If you start the copy array and type 360 in the VCB and followed by 22/ you'll get Todd's result
              Maybe he was using an older version of SU because mine goes to 0.0 too???
              • charly2008C
                charly2008
                Hi rclub24,
                i found a video tutorial, maybe also interesting for ohters who have the same problem.
                I followed the steps in the video, but if i rotate the array i can't get the 360 degree. the View in the measurement box switch to 0,0.
                • C
                  chrisjk
                  Chris Fullmer's Component Stringer?
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&hilit=pluginl
                  Chris
                  • charly2008C
                    charly2008
                    Hell, I do not get it out. I've attached the file.
                    Stargate.skp
                    • GaieusG
                      You can no longer use radial array (scroll down in the page) on that model as it is not circular but elliptical. The shape does not have a single origin to rotate around plus the segments are of no equal length. See the tiny but apparent glitch by the end of the array.
                      Stargate.skp
                      • charly2008C
                        charly2008
                        Thanks r24club, Gaieus an Pilou,
                        it works now without a gaps between and i didn't change anything on the circle
                        . I moved one copy around to the end of the first component and clicked. The circle has 39 segments and so i inserted in the VCB /38. That was it.
                        Karlheinz
                        • GaieusG
                          Ok, my mistake, sorry. I must have done it slightly inaccurately and didn't check.
                          • charly2008C
                            charly2008
                            Hi Gaieus,
                            no problem we all make errors and the only way we learn. My error was that I had forgotten to click at the last position forever. Again thanks to you.
                            Karlheinz
                              For a circle
                              Don't very well understand : why not use copy Rotation by 15° then *23?
                              (with a circle 24 segments by default)
