    Component copy along a circle??
    13 Posts 5 Posters 3.1k Views 5 Watching
      Would Copy Array using Rotate Tool work for you?
      • charly2008C Offline
        charly2008
        Hi rclub24,
        At the moment I can not remember how I can perform this function!
        Karlheinz
          Same as the way you copy using the Move Tool
          [flash=853,505:2xv312yj]http://www.youtube.com/v/CRjnlPRG6rU[/flash:2xv312yj]
            If you start the copy array and type 360 in the VCB and followed by 22/ you'll get Todd's result
            Maybe he was using an older version of SU because mine goes to 0.0 too???
              charly2008
              Hi rclub24,
              i found a video tutorial, maybe also interesting for ohters who have the same problem.
              I followed the steps in the video, but if i rotate the array i can't get the 360 degree. the View in the measurement box switch to 0,0.
                chrisjk
                Chris Fullmer's Component Stringer?
                http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&hilit=pluginl
                  charly2008
                  Hell, I do not get it out. I've attached the file.
                  Stargate.skp
                    You can no longer use radial array (scroll down in the page) on that model as it is not circular but elliptical. The shape does not have a single origin to rotate around plus the segments are of no equal length. See the tiny but apparent glitch by the end of the array.
                    Stargate.skp
                      charly2008
                      Thanks r24club, Gaieus an Pilou,
                      it works now without a gaps between and i didn't change anything on the circle
                      . I moved one copy around to the end of the first component and clicked. The circle has 39 segments and so i inserted in the VCB /38. That was it.
                      Karlheinz
                        Ok, my mistake, sorry. I must have done it slightly inaccurately and didn't check.
                          charly2008
                          Hi Gaieus,
                          no problem we all make errors and the only way we learn. My error was that I had forgotten to click at the last position forever. Again thanks to you.
                          Karlheinz
                            For a circle
                            Don't very well understand : why not use copy Rotation by 15° then *23?
                            (with a circle 24 segments by default)
