    Component copy along a circle??
    13 Posts 5 Posters 2.8k Views 5 Watching
    • charly2008C Offline
      charly2008
      Hi to All,
      need help! I would like to copy a component along a polygon as shown below. I tried "copy along path" but didn't get the wanted result. Is there a ruby which can do that?
      Karlheinz
      • Rich O BrienR Online
        Would Copy Array using Rotate Tool work for you?
          charly2008
          Hi rclub24,
          At the moment I can not remember how I can perform this function!
          Karlheinz
            Same as the way you copy using the Move Tool
            [flash=853,505:2xv312yj]http://www.youtube.com/v/CRjnlPRG6rU[/flash:2xv312yj]
              If you start the copy array and type 360 in the VCB and followed by 22/ you'll get Todd's result
              Maybe he was using an older version of SU because mine goes to 0.0 too???
                charly2008
                Hi rclub24,
                i found a video tutorial, maybe also interesting for ohters who have the same problem.
                I followed the steps in the video, but if i rotate the array i can't get the 360 degree. the View in the measurement box switch to 0,0.
                  chrisjk
                  Chris Fullmer's Component Stringer?
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&hilit=pluginl
                    charly2008
                    Hell, I do not get it out. I've attached the file.
                    Stargate.skp
                      You can no longer use radial array (scroll down in the page) on that model as it is not circular but elliptical. The shape does not have a single origin to rotate around plus the segments are of no equal length. See the tiny but apparent glitch by the end of the array.
                      Stargate.skp
                        charly2008
                        Thanks r24club, Gaieus an Pilou,
                        it works now without a gaps between and i didn't change anything on the circle
                        . I moved one copy around to the end of the first component and clicked. The circle has 39 segments and so i inserted in the VCB /38. That was it.
                        Karlheinz
                          Ok, my mistake, sorry. I must have done it slightly inaccurately and didn't check.
                            charly2008
                            Hi Gaieus,
                            no problem we all make errors and the only way we learn. My error was that I had forgotten to click at the last position forever. Again thanks to you.
                            Karlheinz
                              For a circle
                              Don't very well understand : why not use copy Rotation by 15° then *23?
                              (with a circle 24 segments by default)
