    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
    • jeff hammondJ Offline
      jeff hammond
      crazy 😲
      nice one chris!
      dotdotdot
      • N Offline
        notareal
        Thanks! I am sure meny will find this usefull. There is still some extra steps needed to make a chain... I wonder how soon some will make working SP roller chain with this
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
          Click Draw
          couple more....
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          • E Offline
            Ecuadorian
            And thus SketchUp became the easiest way to design a roller coaster.
            Would it be possible to have each component connect to the beginning of each line segment, but not scale.
            Right click > Reset scale. You have to do this for each instance. There must be a "mass reset scale" script somewhere. EDIT: It seems there isn't. Make sure to set a keyboard shortcut for "reset scale" so you can do this quickly.
            Hey, Jeff, how about something like this?
            -Miguel Lescano
              Click Draw
              Wow!....did you draw that? Have you tried the script yet or is that your first try with it?
              • E Offline
                Ecuadorian
                😆 It's a photo, Jeff. This is a famous house by Spanish architect Antoni Gaudí. I'm just suggesting that this script will now make this kind of crazy things possible in SketchUp.
                But I know you were just kidding. 😄
                -Miguel Lescano
                • pbacotP Offline
                  Very cool plugin that ultimately should be very useful, for architectural modeling not just necklaces. Thank you Chris.
                  We have something like this in our CAD program. Some of the different things that CAD feature does is: place objects contiguously or at a user-set spacing, stretch/shrink and bend objects objects or not. rotate objects or not, rotate randomly, fill the length of a path with various "fudge" settings (gives different number/spacing of objects within path), offset objects from path. Just some options to think of possibilities.
                    Suggestion : a little rotation between each components? 😉
                    Ah damned that was yet in the Todo list 😳
                    So this one : change colors between each components (or according with the segment) 😄
                    PS We are listening crickets or cicida during the video plug 😉
                      Click Draw
                      I was gonna ask about the crickets too. Must have been a late night thought process that had to get you up and working.
                        MartinRinehart
                        Blows me away, Chris. What was the inspiration?
                        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                        • kenK Offline
                          ken
                          @click draw said:
                          first attempt....! Thanks Chris.
                          Click Draw
                          How did you get the components to overlap? Seems to me, what ever you did could be used to make an anchor chain.
                          Thanks in advance.
                          Ken
                            Click Draw
                            Thanks in advance.
                            Ken
                            You make the component and string it along... then edit the component so it is longer or a differing shape and it will overlap etc. I outlined a chain making idea earlier...
                            • simon le bonS Offline
                              simon le bon
                              Dear Chris,
                              A lot of people are waiting for long a set of tools to make copy of objects along a path.
                              With this Component Stringer, we get one of them. A cool one.
                              It is very easy to do various necklaces with it.
                              I have played it and threw an eye on some corners of it's possibilities.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer007th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer008th.jpg
                              What it is not made for:
                              It is not made to make chains when links are imbricated together.
                              I have tried TIG solution (not exactly the same) with a rather poor result..
                              @tig said:
                              Make half chain link (U) and use this tool then edit that chain and copy/hand the U geometry into an O loop of say 2.2 the original length, now you have your links; us 'make unique' on one of the links, edit it and rotate its contents 90 degrees. Select every other link and replace with this rotated one... a chain... done.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer005th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                              Also this tool is not made to mix more than one component on to the path. If we need to do that, we have to do another way.
                              Thnk you again for this tool! you have a great talent to concoct easy but useful and strong tool..
                              My respect, Simon.
                                Click Draw
                                Hi Ken,
                                Like TIG said, make your component and then edit it and do what you like to alter the dimensions and shape and it will update as you do it. Very cool. You also have to make sure the axis is in the proper position on your component. Hope that makes sense. I'll be trying more shapes and posting here soon. Awesome script!
                                Jeff
                                • MALAISEM Offline
                                  MALAISE
                                  Very efficient tool to create wood roofs, barrels ,boats and arches.
                                  Maybe Components axis should be shown
                                  PAM
                                  • JClementsJ Offline
                                    JClements
                                    If you could also give user options to also scale along the component's other axes:
                                    (1) axes A-B and A-C, or (2) axis A-B, or (3) axis A-C, then you'd have something similar to a blend-along-path.
                                    And if it could then "skin" the sides (vertices) of the components, it would be equivalent to a Scaled-Extrusion Along a Path.Idea for another Script.png
                                    Idea for another Script.skp
                                    • W Offline
                                      wolfy
                                      Another gem for the jewel box! Thanks Chris ☀
                                      • utilerU Offline
                                        utiler
                                        Hi Chris, thanks for this great work!!! It is very close to something i have asked questions about in the past....
                                        Like Pilou, I think it would be great to see some rotation options at each segment. Also the suggestion of nil scaling would be nice too so the component is think dependent on segment length.....
                                        I haven't played with it yet but I can say now that it's a BOMB!!!!!!
                                        Just Curious...
                                          d12dozr
                                          http://forums.sketchucation.com/viewtopic.php?p=200754#p200754
                                          http://goo.gl/f7ooYh
                                          • Chris FullmerC Offline
                                            The rotation options are implemented here, so they will be in the next release. I also like John's ideas about scaling the components smaller. But that will take a lot of code writing so I would not count on seeing that soon. And I will not be using this tool to add a skin. That's very complex.
                                            But I will say the rotation is working great and is perfect for chains. Nil scaling would be easy to implement. I'll put that in too. So I'll hopefully get this released within the next 24 hours.
                                            Thanks for all the comments!
                                            Chris
                                            All my Plugins I've written
                                            • 8
                                            • 9
                                            • 2 / 9
