    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
      Click Draw
      Hey Chris,
      Another awesome script. Thanks very much! I agree that you are at a point now where you could charge for your scripts but I also understand that you need to be comfortable doing that. I will gladly support you when you do. I have bought SOME scripts and I hardly use them, yet. It's obvious that you enjoy writing them and knowing others appreciate it definitely must help. How about you set up that PayPal and let people donate as they download. I'm not sure how long it takes to write these but I'm sure you have quite a few hours put into it so far. Anyway, keep up the great work! Your a good guy Chris!
      Cheers,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • ArcA Offline
        Arc
        very cool and powerful.
        thank you, Chris.
          Click Draw
          first attempt....! Thanks Chris.
          • jeff hammondJ Offline
            crazy 😲
            nice one chris!
            • N Offline
              notareal
              Thanks! I am sure meny will find this usefull. There is still some extra steps needed to make a chain... I wonder how soon some will make working SP roller chain with this
                Click Draw
                couple more....
                • E Offline
                  Ecuadorian
                  And thus SketchUp became the easiest way to design a roller coaster.
                  Would it be possible to have each component connect to the beginning of each line segment, but not scale.
                  Right click > Reset scale. You have to do this for each instance. There must be a "mass reset scale" script somewhere. EDIT: It seems there isn't. Make sure to set a keyboard shortcut for "reset scale" so you can do this quickly.
                  Hey, Jeff, how about something like this?
                  -Miguel Lescano
                    Click Draw
                    Wow!....did you draw that? Have you tried the script yet or is that your first try with it?
                    • E Offline
                      Ecuadorian
                      😆 It's a photo, Jeff. This is a famous house by Spanish architect Antoni Gaudí. I'm just suggesting that this script will now make this kind of crazy things possible in SketchUp.
                      But I know you were just kidding. 😄
                      -Miguel Lescano
                      • pbacotP Offline
                        Very cool plugin that ultimately should be very useful, for architectural modeling not just necklaces. Thank you Chris.
                        We have something like this in our CAD program. Some of the different things that CAD feature does is: place objects contiguously or at a user-set spacing, stretch/shrink and bend objects objects or not. rotate objects or not, rotate randomly, fill the length of a path with various "fudge" settings (gives different number/spacing of objects within path), offset objects from path. Just some options to think of possibilities.
                          Suggestion : a little rotation between each components? 😉
                          Ah damned that was yet in the Todo list 😳
                          So this one : change colors between each components (or according with the segment) 😄
                          PS We are listening crickets or cicida during the video plug 😉
                            Click Draw
                            I was gonna ask about the crickets too. Must have been a late night thought process that had to get you up and working.
                              MartinRinehart
                              Blows me away, Chris. What was the inspiration?
                              • kenK Offline
                                ken
                                Click Draw
                                How did you get the components to overlap? Seems to me, what ever you did could be used to make an anchor chain.
                                Thanks in advance.
                                Ken
                                  Click Draw
                                  Thanks in advance.
                                  Ken
                                  You make the component and string it along... then edit the component so it is longer or a differing shape and it will overlap etc. I outlined a chain making idea earlier...
                                  • simon le bonS Offline
                                    simon le bon
                                    Dear Chris,
                                    A lot of people are waiting for long a set of tools to make copy of objects along a path.
                                    With this Component Stringer, we get one of them. A cool one.
                                    It is very easy to do various necklaces with it.
                                    I have played it and threw an eye on some corners of it's possibilities.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer007th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer008th.jpg
                                    What it is not made for:
                                    It is not made to make chains when links are imbricated together.
                                    I have tried TIG solution (not exactly the same) with a rather poor result..
                                    @tig said:
                                    Make half chain link (U) and use this tool then edit that chain and copy/hand the U geometry into an O loop of say 2.2 the original length, now you have your links; us 'make unique' on one of the links, edit it and rotate its contents 90 degrees. Select every other link and replace with this rotated one... a chain... done.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer005th.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
                                    Also this tool is not made to mix more than one component on to the path. If we need to do that, we have to do another way.
                                    Thnk you again for this tool! you have a great talent to concoct easy but useful and strong tool..
                                    My respect, Simon.
                                      Click Draw
                                      Hi Ken,
                                      Like TIG said, make your component and then edit it and do what you like to alter the dimensions and shape and it will update as you do it. Very cool. You also have to make sure the axis is in the proper position on your component. Hope that makes sense. I'll be trying more shapes and posting here soon. Awesome script!
                                      Jeff
                                      • MALAISEM Offline
                                        MALAISE
                                        Very efficient tool to create wood roofs, barrels ,boats and arches.
                                        Maybe Components axis should be shown
                                        PAM
                                        • JClementsJ Offline
                                          JClements
                                          If you could also give user options to also scale along the component's other axes:
                                          (1) axes A-B and A-C, or (2) axis A-B, or (3) axis A-C, then you'd have something similar to a blend-along-path.
                                          And if it could then "skin" the sides (vertices) of the components, it would be equivalent to a Scaled-Extrusion Along a Path.Idea for another Script.png
                                          Idea for another Script.skp
                                          • W Offline
                                            wolfy
                                            Another gem for the jewel box! Thanks Chris ☀
                                            • 2 / 9
