    Vray problem
    renderpluginsextensions
    20 Posts 4 Posters 4.4k Views 4 Watching
    • S
      sketchup_fan
      Hi guys, recently i've built a two tower complex with lots of detail (trees, cars, lights ...), but when i tried to render it with vray for sketchup, the render window didn't normally opened as it was supposed to be. I waited fro 2.5 hours but nothing happened? Could you please help me, and tell what's the problem? By the way the file size is 6.4MG, sketchup 7 and vray for sketchup 6.
      I see guys in this forum who have in their models lots of detail and accomplish great renders, but this time the render didn't work for me.
      Thanks.
      • thomthomT
        You're using the original version? In the About section, does it have a version number?
        • D
          dedmin
          Maybe a components texture problem. But if we have textures applied separately to all faces in a component and a texture to the component itself is the bug still a fact?
          • thomthomT
            It's not a bug. Just really annoying as V-Ray takes an insane amount of more time to process.
            And yes, any material to groups & components will increase VfSU's parsing time. Remove them all.
            The original seemed to be quicker in this regard - but that was because it incorrectly processed the objects.
            • D
              dedmin
              Too bad - the CutList plugin uses the component's material for calculations.
              • thomthomT
                It's not the file size. Large file size usually just indicate large textures in the model. Not a good measurement on how much geometry there is. V-Ray can render large scenes. You might have to output to raw VrImage some times if you run into 32bit memory limit. But that can happen on small scenes as well - it all depends on your settings.
                What really kills time is materials onto groups/components. Though, the latest one is somewhat slower to parse the scene than the original. But the original wasn't parsing correctly. Currently they are working on a update that will improve things.
                (ps. don't mention anything about cracks.)
                • S
                  sketchup_fan
                  Thank you all guys.
                  • S
                    sketchup_fan
                    Raw vrimage?, what is that? Could you please explain it to me and how can i acheive render results using it? Remember the render window of vray doesn't open when i hit the render button at all. I tried to find out what vrimage meant but nothing, could you help me?
                    • thomthomT
                      Render to VrImage means rendering directly to file and not using the Frame Buffer: http://software.asgvis.com/index.php?option=com_content&view=article&id=16:vfr-tutorial-a&catid=16:v-ray-for-rino
                      But that won't sort out your large parsing time. What version did you have? What does it say in the About section, if there is any?
                      • thomthomT
                        Also, have you tried removing materials from Groups/Components?
                        There's a plugin to do that for you: http://forums.sketchucation.com/viewtopic.php?f=180&t=13711#p102323
                        • S
                          sketchup_fan
                          It's a vray for rhino which in a weird way works in sketchup. It's a plugin. When i go to the about section i fing 'vray for rhino' and no version number. In a weird way it works inside the sketchup program.
                          • thomthomT
                            No. It's not VRay for Rhino. But ASGVis makes V-Ray for Rhino as well, and the original version, which you have, did have some references to Rhino in the UI for the Sketchup version.
                            It's been a while since I used the original version now. But try to remove group/component materials.
                            • S
                              sketchup_fan
                              Do you suggest buying the original version of vray for sketchup 7 instead of the 'original' version which my 'friend' has? (hehe...) Would this move improve render process? Oh, and how i remove materials out of groups/components, i just
                              delete the textures that i'm using in sketchup?
                              • thomthomT
                                Not sure if you can even get the original version any more.
                                Personally I prefer the new version over the old. Even though it means you need to be really strict about not adding materials to groups/components. There is another quick where you need to open the Option window before saving your model i fyou made any changes to materials. But all in all, the bugs in the new are more acceptable than the bugs in the old. With the new you can match the V-Ray camera to the Su camera - in the old it'll always be slightly off.
                                But I can tell you, that the version they are working on now, which is in beta, is looking really really promising. I'm a bit unsure if it's a free upgraded for existing users or not... you might want to check with them if buying a license now will give you the next version.
                                • PixeroP
                                  Pixero
                                  Are you beta testing it?
                                  • thomthomT
                                    Yup. You can sign up for testing - it's been made public. Not sure if they accept more right now, but they should be opening up more soon.
                                    But it's not a stable beta - lots of quicks, but it's a brilliant chance to provide feedback back to the developers.
                                    • PixeroP
                                      Pixero
                                      I can only find where to apply for Mac beta testing. Not windows?
                                      Edit: Found it!
                                      • thomthomT
                                        Then it sounds like you had a corrupted texture in the model.
                                        Only thing I can recommend is add the textures back one by one and see when it fails.
                                        • thomthomT
                                          I think I remember from the ASGVis forum that CMYK textures can cause problems...
                                          • S
                                            sketchup_fan
                                            Ok guys, i found what the problem was. I just removed all the textures in the model and the render took only 5 minutes.
                                            Thank you all. Now the question is, how am i going to make the scene look realistic, if all the textures are removed from the model?
