    What do Foreign versions of SketchUp say in the title?
    9 Posts 6 Posters 855 Views 6 Watching
    • Al HartA Offline
      Al Hart
      The English version always contains "- SketchUp" in the title of the main SketchUp window.
      (Preceded by the model name)
      Do the foreign versions use the same phrase?
      If you are running a foreign version, could you look and let me know?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
        I only run the English version, but just wanted to note that mine say " - Sketchup Pro"
        • Al HartA Offline
          Al Hart
          Thanks,
          I didn't get any responses yet, so I posted the question in the French and German forums.
          Al Hart
          • massimoM Offline
            massimo Moderator
            The same here with SU 6 free italian version.
            • Al HartA Offline
              Al Hart
              Thanks - this has been a big help
              (we are trying to find a good way to identify which Windows window is the main window for the SketchUp application.
              We were looking at an old application credited to TBD, (MultitouchSu.cpp), which suggests using the process ID, class name (old name no longer is valid) and "- SketchUp" to find the proper window.
              When you do things like this, you have to make sure SketchUp hasn't made changes over the years which mess things up.
              Al Hart
                Aerilius
                Sketchup 6 Deutsch: "Unbenannt - Sketchup"
                The english SU7 has a bug. It keeps the title "Untitled - Sketchup" after you load another file.
                  Not mine 😉
                  • K Offline
                    kwistenbiebel
                    I hope the Japanese version says 'Banzai' and the Scottish version 'Skeeeeeetchuuuuup' 😄
