    Bumpmap for Glass
    renderpluginsextensions
    11 Posts 5 Posters 2.6k Views 5 Watching
    • holmes1977H Offline
      holmes1977
      hi all
      Im looking for a good bumpmap for glass. Im modeling a refurbished old building as you can see and want to get distortion in the reflections.
      http://i607.photobucket.com/albums/tt154/holmes1977_album/Queen_06.jpg
      Exaggeration makes a dull story better.
      • soloS Offline
        solo
        Image is not showing.
        What render engine you planning to use?
        http://www.solos-art.com
          holmes1977
          hi Solo
          Im trying to learn V-Ray
          • jeff hammondJ Offline
            jeff hammond
            @holmes1977 said:
            hi all
            i can't help with the map but i can help with getting your picture to show up πŸ˜„
            EDIT- haha.. nevermind
            dotdotdot
            • soloS Offline
              solo
              Use a water bump, oversize it and make it a small value like .5
                holmes1977
                hahaha
                really that simple
                thanks Solo I'll give it ago
                • N Offline
                  NewOne
                  If it's double glazing, then between the two foils of glass is low pressure gas (Argon), or vacuum. That is why the glass surface is not planar but slightly concave. I suggest to try with this bump... I don't know how accurate is, but you can give a try. Don't tile it! Fit the image on each window.
                  It's a 16 bit grayscale PNG. I hope it won't make strips.
                  glass bump_.zip
                    holmes1977
                    @NewOne
                    Cheers Mate I'll try it out
                      I did some experiments with warped glass before:
                      http://forums.sketchucation.com/viewtopic.php?f=322&t=18096&start=30#p149199
                      http://forums.sketchucation.com/viewtopic.php?f=322&t=18096&st=0&sk=t&sd=a&start=45#p149570
                      If you look at a building made out of glass you'll notice that each glass panel bulges, the distortion follows the frame of the glass. It's due to the different pressure between the inside and outside I believe.
                      • N Offline
                        NewOne
                        inside and outside of the building? πŸ˜„ I hope that doors and windows are not so good sealed... Because who's sleeping there, might wake up with a terrible headache because of oxygen lack. πŸ˜„
                          holmes1977
                          Cheers Thomthom
                          Thats perfect, I have abit of experimenting to do.
