    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      @wrc86 said:
      http://img580.imageshack.us/img580/8752/capturadepantalla201108ft.th.png
      it's not working for me, it doesn't show any error when I start SU
      It just to work with my old OS, now I'm working with OS X LION
      hm... not sure what it could be. with no error message at all.
      can you open the Ruby Console before you try to use CleanUp and see if you get any messages there?
        Sakika
        This might be a "stupid" question, but how do i install this plugin on sketchup? Because it is an .rb file and i dont know what program to open it?!
        Thanks,
        Sakika
        • TIGT Online
          Sakika
          You really need to read some help files on general 'basic Plugin installation' 😕
          You do not need to 'open' a Ruby .rb file at all [you can open it with a plain-text-editor and read it, as there are often 'notes' at the start, but its main contents might not be very easy to understand!].
          You simply put the .rb file into the ../Sketchup../Plugins folder [there's a folder tree diagram].
          Note that this particular tool also needs a 'TT_Lib2' - there's a link to get it on the tool's first 'download' page - this is a zipped folder of extra 'helper' files. The folder goes into Plugins with its files still inside it [there's a folder tree diagram to help you too] - Note: never move files out of these subfolders as it will break things! You then need to restart Sketchup to get everything operating.
          The new tool will become available to you as explained in its installation/usage note... For this tools there's some 'Access' instructions and a screenshot of the menu item you should see...
            Sakika
            Thanks for ur help TIG
            I really Apreciate it!
            Sakika
              bonobomidwest
              Thanks man. This was a HUGE help.
                I split off the discussion of the issues with Safari 5.0.6 into a separate thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842
                  OSX Users:
                  Download TT_Lib 2.5.5 for a patch that will fix the empty window.
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
                    Version 3.1.5
                    Minor update to fix an internal GC issue.
                      small08
                      Thank-you TT, for all your hard work.
                        driven
                        @thomthom said:
                        Version 3.1.5
                        should this remove the html temp files?
                          Ben Ritter
                          Thank you!
                          • P Offline
                            putnik
                            Thank you Tom!
                            http://keshas.info
                              chango70
                              Just great!
                                Clean up of Clean up! 😉
                                  @driven said:
                                  @thomthom said:
                                  Version 3.1.5
                                  No. Afraid not. Anything related to that will occur in TT_Lib. I'll have a proper patch in a day or two.
                                  • pep75P Offline
                                    pep75
                                    Thanks!
                                      mberger
                                      Thank you.
                                      I have a feature request:
                                      Could you have the option to not purge components that are unused but have "XXXX_proxy" instances.
                                      I use the proxy feature in maxwell exporter a lot. It allows me to swap in the more complex geometry on export.
                                      Functionality would be a checkbox i think and an extra check when deleting an un used instance if the corresponding instance with _proxy appended to the name is used and iff that is true not delete it.
                                      • dereiD Offline
                                        derei
                                        It seems like your last version doesn't clean as good as the previous did. I wanted to clean some lines from a geometry I modified, but they remained. I had to delete them manually.
                                        DESIGNER AND ARTIST DEREI.UK
                                          What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
                                          Got sample model? And screenshot of settings?
                                          • 3 Offline
                                            3rdEye
                                            Hmmm, strange....
                                            when I install 3.1.5 and try with either TT_Lib 2.5.4 or 2.5.5 I get a blank Window on hitting the Cleanup Menue Item. So I switched back to 3.1.4 and Lib 2.5.4, which is the combination that works.
                                            I use SU 8 Pro, WinXP 32bit,
                                            but anyway - thx again for keeping it up!
                                            all the best, 3rdEye
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 48
                                            • 49
                                            • 20 / 49
