    Can we select by layer?
    10 Posts 6 Posters 14.6k Views 6 Watching
      troyhome
      I hope this is a doh! moment, but is there a way to simply select everything on a given layer?
      IOviz.com
      SU Pro 2024 PC
      • takesh hT Offline
        takesh h
        Not with native SU tools, but with Didier's Layer manager, it's possible.
        Try [Select/Deselect layer content] tool of Layer manager.
        • honoluludesktopH Offline
          honoluludesktop
          Perhaps I don't understand the question, but why can't you simply turn off the layers you do not want to see, then work with whats left? This works unless the entities are part of a component. In that case you edit component, then turn the unaffected layers off.
            It is built-in. Select an Object on the required Layer. Right-click and in the Context-Menu near the top is Select... Pop this out and there' Select all on Same Layer... All active Objects on that Layer are Selected.
              troyhome
              This worked- of course!!!
              You can't select by layer unless you're in an active group or component, and all my objects were groups or components. I'll have to give a look at Layer Manager!
              Thanks all
              IOviz.com
              SU Pro 2024 PC
                After you have selected all of the objects on the same layer [even if they are in different entities sets], what are you going to do with them ?
                assume the model is defined as 'model' and the layer is 'layer'
                ss=model.selection
                ss.clear
                model.entities.each{|e|ss.add e if e.layer==layer}
                model.definitions.each{|d|d.entities.each{|e|ss.add e if e.layer==layer}}
                ALL entities on 'layer' are now 'selected'...
                NOW what will you do ?
                • takesh hT Offline
                  takesh h
                  @tig said:
                  It is built-in. Select an Object on the required Layer. Right-click...
                  Yes and No, because [Select by right-click context menu] works only on a free single entity (such as an edge or face), not a group or a component. And it goes against the golden rule of SU "all free entities should be in Layer 0".
                  However, once invoked, the function selects groups and components as well as free entities.
                  So if you don't mind going over trouble of changing the layer of a free entity for the sake of the function, yes, it could work.
                  • G Offline
                    glro
                    I came to the conclusion i needed such a plugin too
                    i didn't find anything simple already made
                    so i made it (in a simple way)
                    the plugin writes the answer of the prompt in a text file to recall it for the following prompt (some people might not like it)
                    and it would be much better to have a popup window to choose among the layer you want to select instead of having to type it (but it is complicated and i don't know how to do that)
                    but, here is the simple plugin
                    select by layer
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      Layers Panel does that :
                      http://sketchucation.com/plugin/751-layers_panel
                      • G Offline
                        glro
                        yes, i tried
                        but it doesn't work on my computer
                        bug related to IE v11, it seems...
