    SketchUp edges missing in OS X not in Windows
    5 Posts 4 Posters 1.4k Views 4 Watching
    • F
      Fernando Martin
      Hi all,
      I have a problem with SU on my MacBook.
      When modeling always some edges remain invisible. It seems to be a SU issue because when I switch to Windows that problem do not exist.
      I did a search in this forum without success. I found that others have the same problem, but no solution or explanation.
      I apologize if I missed the solution. I'll be grateful if someone leads me to it.
      Macbook 1,83 Ghz Intel Core Duo 1,25 GB RAM GMA950 OS X10,5,7
      Windows XP
      • C
        caronte01
        Hi fernando. I have a similar computer, and experience something similar. It probably has to do with the video card drivers. If you switch to wireframe, do edges reappear?
        • F
          Fernando Martin
          Hi Santiago,
          Yes, when I switch to wireframe the edges are seen. But they don't in hidden lines.
          In another forum I was told to change the Video Card driver. (GMA 950).
          So far I did not found where to download it. Intel page does not have downloads for Mac.
          • B
            bjanzen
            Mac drivers are done by Apple and vendor (Intel, in this case). Turn off HW Accel for this card.
            b
            • SketchUp Guide TommyS
              Turning off hardware acceleration should do the trick, just as Barry suggests.
              I've found the following page from Apple really useful to see if a particular graphics card provides the necessary OpenGL 1.5 compliance that SketchUp requires:
              http://developer.apple.com/graphicsimaging/opengl/capabilities/index.html
              Since you're running OS X 10.5, it looks like the GMA950 only supports OpenGL version 1.2. On OS X 10.6, is supports OpenGL 1.4, which is better but not quite there.
              Regards,
              SGT
