    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 197.5k Views 41 Watching
      Jim
      Sorry 'bout that, Dekker. I am haphazard with my plugins - but I'm glad you found inputbox.rb
      Any thoughts on the importer?
        The link to inputbox.rb is dead.
          Does it handle materials in any way?
            Jim
            No. I don't remember seeing a "material" or "color" property for dxf entities. Isn't the color based on an entities' layer?
              You are right.
              A DXF file gives objects layers, and those layers have colors.
              If you take the SKP layers the colors export as random colors.
              Even with similar SKPs newly made layers get unconnected colors.
              It's possible to rationalize a DXF by post processing it's text - I have a commercial tool I've written which uses the native DXF exporter, but where the client wanted all DXF layers to be consistently colored; so it has a 'lookup table' and ensures consistency by 'stream-editing' the DXF's text after it's made.
              Another way to have materials==colors is to export a custom made DXF but ignore the SKP's layers and using each material as if it were a DXF-layer... that way objects in the DXF are then grouped by each DXF 'layer' which is really made from the SKP's material-color rather than the proper SKP-layer...
                Jim
                Dec 2011 - I have removed the external dependency on my inputbox.rb - it is no longer required as a separate download. Also, I attached the download to the first post of this topic rather than linking to an external site. Hopefully, these changes will make it easier for folks to try.
                  Is DXF extendable? I wonder if AutoDesk writes DXF with extra material info..?
                    A DXF can include all the types of data that you get in a DWG file itself.
                    However, as objects have layers and layers have colors, that's it.
                    You can assign attributes to objects containing additional info, so you can pass [otherwise-unused] data... but how that's useful later on is questionable.
                      I'm trying to find a good way to export a Revit model to SketchUp.
                      I have tried exporting to FBX and then use Autodesk's converter utility to convert to DAE - but that fails on import every time on any model in SU. Fail in Blender as well.
                      DWG and DXF import in SU - but uses layer material, as you describe. However, if I import the same DXF into another Autodesk application like 3DS - the materials are like how they where defined in Revit. And that is why I'm exploring this topic.
                        Jim
                        FreeDXF imports acad layers as SketchUp Groups, so it may be possible to color the Groups according to their acad layer color number.
                          syfyguy
                          It doesn't seem to work for me. I have Sketchup 8, with the new maintenance pack. It shows up in the plugins menu, then when executed it asks for arc segments, etc. When I click ok, nothing shows up. I'm using DWGeditor 2007 to create dxfs in ASCii 2007 format.
                            Jim
                            Can you post or send the file?
                              Tenere
                              😒 %(#4000FF)[I've got a script not loading error on start with free version 8.0.4811.
                              I would assume I had the files in the right places although I can't see the folder layout image in the script posting - just an image name.
                              Bound to be missing the obvious, be grateful if someone could nudge me in the right direction......cheers.
                              Ooh one other question......Can I load the SU pro trial in tandem with my free version without bu#@ering it up or compromising the trial?....would quite like to see what I'm missing.] πŸ‘
                                Capture.PNG Does you Sketchup Plugins folder look like this ?
                                  Tenere
                                  %(#0000FF)[πŸ‘ Hi Tig
                                  Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
                                  I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
                                  Error:]
                                  Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
                                  no such file to load -- inputboxError Loading File freedxf_ext.rb
                                  %(#0000FF)[.......The file is definitely there!
                                  Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
                                    JMdesigns
                                    I am having the same problem? but it does not let me inmport
                                      The download page's image is wrong !
                                      There should also be the file
                                      inputbox.rb
                                      IF you get the latest zipped version of the tool it should include that file !
                                        Tenere
                                        Bingo....your a star Tig
                                        That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
                                          juergen
                                          Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
                                          As all my DXFs are in cm I can not use FreeDXF.
                                          Please consider supporting metric drawings.
                                          PS: If somebody knows a way, please reply!
                                            1" is 2.54cm
                                            therefore
                                            1cm is 0.393700787401574803" [1/2.54]
                                            However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
