    [Plugin] 2D Tools
    791 Posts 178 Posters 529.4k Views 177 Watching
    • jeff hammondJ Offline
      jeff hammond
      confirmed, tab now works on mac.
      i didn't know that's what tab was supposed to do. ha
      that makes 2D tools even more awesome β˜€
      thank you
      dotdotdot
        Brett McAllister
        Hi Tig
        I noticed the edit 2d text function no longer works in version 8.
        The option to edit the text shows up in the context menu but doesn't pop up a dialog box.
        This is the error I got.
        Error: #<NameError: undefined local variable or method db' for TextTool2D:Class> 2DtextTool.rb:379:in edit'
        Running windows xp sp2
        Cheers
        Brett
          dedmin
          When trying to use Edit 2D text I got this:
          Error; #<NoMethodError; undefined method `db' for TextTool2D;Class>
          C;/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2DtextTool.rb;379;in `edit'
          C;/Program Files/Google/Google SketchUp 8/Plugins/2Dtools/2D#loader.rb;186;in `activate'
          C;/Program Files/Google/Google SketchUp 8/Plugins/SectionCutFace.rb;437;in `call'
          WinXP SP3
            @brett mcallister said:
            Hi Tig
            Cheers
            Brett
            You should have deBabelizer.rb in the Plugins folder. It's in the main zip file?
              WinXP SP3
              Not sure about the SectionCut error ???
                v4,7 error... However, I have now managed to reproduce the glitch πŸ˜’ with v8 ... and v4.8 will be issued shortly πŸ˜’ ...
                  dedmin
                  WinXP SP3
                  Reinstalled the 4.7 and now the error is this:
                    I've now got these new v8 errors trapped in '2D Text' and '2D Line Style' "edit" modes - see v4.8 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                    Double checking that no other methods are rubbished by the less forgiving PC-Ruby in v8... πŸ˜’
                    EDIT: There shouldn't be any others - but that's not to say you lot won't find something that's broken... keep looking πŸ˜•
                      dedmin
                      Thanks,TIG! πŸ‘ πŸ‘
                      • Didier BurD Offline
                        Didier Bur
                        Hi TIG,
                        I'm always having this error too, even with the latest version. When setting the Z plane altitude for instance:
                        C;/Program Files/Google/Google SketchUp 7/Plugins/2Dtools/2DzplaneTool.rb;59;in `onMouseMove'
                        Error; #<NoMethodError; undefined method `db' for #<Zplane2D;0x1285ba60>>
                        DB
                          Thanks Didier...
                          I just knew that someone would have another problem!
                          It was a stupid typo on my part that hadn't been reported before... 😳
                          Here's v4.9 that fixes the 'db' glitch in the 'Set Z-Plane' tool.! πŸ€“
                            Didier Bur
                            Cool !
                            So reactive πŸ˜‰
                            DB
                            • CadFatherC Offline
                              CadFather
                              icons updated as well (thanks TIG)
                              Icons.zip
                                Thanks - I'll include them for the next update - meanwhile anyone who wants them now... please replace the original Icons with these...
                                  Here's v5.0 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                  The db arguments etc are parenthesized in (). Various minor glitches in text etc have been addressed. The ES lingvo & help files have also been updated etc - many thanks to Defisto for his nit-picking that goaded me into the update! CadFather's new toolbar button icon set is also include if you want to swap over to that...
                                    define
                                    @tig said:
                                    Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                    πŸ€“
                                    hello TIG, thx for your 2d-toolset...I'm using it all the time and would'nt know how to get along without it.
                                    But I have to second ThomThom with his question, if one 'sotospeak' could make the 2dtools work with
                                    your 'work-planes' too? This would make it into something even more versatile.
                                    You answered ThomThom with a link - I can't however figure out what you are pointing at.
                                    If there's already a means to switch the 2dtools z-axis to any 'temporarily active one' please
                                    give me a hint.
                                    thx a lot for the 2dtools and the 'workplane-plug' and all the other plugs as well
                                      Ben Ritter
                                      I can use the hatching option only once, thereafter, I the hatch selection window doesn't open. Tried it with SU7 and SU8, same issue.
                                      Any suggestions?
                                        Ben Ritter
                                        Sorry for the bother. I'm short on memory and lazy. Just looked at some previous posts and found the answer.
                                        • EarthMoverE Offline
                                          EarthMover
                                          This would in fact be quite redundant. The work planes are used in a similar manner to the 2D tools, as they create a "shield" to prevent the inferencing of the native tools to the geometry on the opposite side of the plane. You can draw directly on it as it's a locked group and delete it at will. The 2D tools do much the same except they are restricted to the X,Y axis for 2D drawing, but still allow you set the Z, which creates an invisble 2D work plane on that height. The work plane plugin allows similar restriction, only it's not restricted to X,Y only and it works with the native toolset. You could technically set a work plan on the x,y axis at a Z height and use the native tools to draw in restricted 2D. Using the 2D tools to go the other direction would negate them from being 2D at all.
                                          Content Creator at Skapeup
                                            I find that the native tools - especially the line tool all to often pick inference in the Z-Axis - so when I think I've drawn a shape on a plane I've in fact drawn a 3d shape.
                                            That's why it'd be nice to have a tool that restricted drawing to the arbitrary set plane.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 39
                                            • 40
                                            • 15 / 40
