    [SQ] Move an object into a Group ?
    7 Posts 4 Posters 674 Views 4 Watching
    • simon le bonS
      simon le bon
      [SQ] for "Simple Question" (rather than the "Silly Question" I have in mind 😠 )
      Some people advocate working primarily with groups and components. One thing until now had prevented me to do this way. This is that I hadn't actually found how to simply move an object into a group, or from a group into another one!
      For me, the only solution is to Edit/Copy this object, then open the group and Edit/Past it, and only after that Move it in place.
      You will agree with me that this process is laborious 😞 !
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MoveIntoGroup.jpg
      So. Does Anybody Knows a solution??
      simon
      • GaieusG
        Hi Simon,
        Instead of Paste and start moving about, just "paste in place". This item is in the Edit menu but you can assign a shortcut key (I use Shift+Ctrl+V for instance).
        • takesh hT
          takesh h
          Hi Simon,
          I cannot stress the usefulness of Outliner enough.
          • simon le bonS
            simon le bon
            thank you sirs,
            Two good tips indeed.
            The Gaieus one suggests to first move/copy the object (here the translucid dome) on to its place on the grouped shape, and then: Cut it - Open the group - and PasteInPlace... >>handy this way 👍
            The takesh h one using the Outliner is evidently very helpfull to work between several groups and components. I had never try to grab one in another 👍
            (I just regret it seems not possible to grab just a copy (CTRL) of the group or component. 😕 )
            😄 simon
            • X
              xrok1
              you can use copy and paste functions after selecting through the outliner as well. ctrl drag.
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
              • simon le bonS
                simon le bon
                Hi xrok1,
                thank you for having completed
                Yes: CtrlC/CtrlV is working with a group/component selected through the Outliner.
                Also I have found that a doubleClic on a group through the Outliner open it.
                But,Ctrl drag is not working for me!?? Is it really for you?
                simon
                • X
                  xrok1
                  i thought it was but when i tried it again it wasn't. my mistake 😳
