    [req] unique texture
    15 Posts 5 Posters 3.2k Views 5 Watching
    • X Offline
      xrok1
      would anyone be able to do a script that would allow "Make Unique Texture" to be applied to multiple faces at once?
      this could be very handy and time saving when working with photomatch...
      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
      • E Offline
        Ecuadorian
        Thomthom said the API didn't provide this function, but if the user sets a shortcut for this function (or any function for that matter) the API can trigger this shortcut. So perhaps you could change your Ruby request to:
        "Repeat shortcut over multiple faces"
        ...or something like that.
        -Miguel Lescano
        • X Offline
          xrok1
          or step through selection 😉
          whatever you call it, i'd call it handy!
          • Chris FullmerC Offline
            Thom's done more with materials than myself, but it seems like there might be some way to not do a simple .make_unique, but perhaps create a new texture from the existing. It seem slike it would require finding the original image, make a new material that uses the original image as the texture, then apply the new material to the face, using the previous UV coordinates.
            Is all of that possible?
            Chris
            All my Plugins I've written
            • X Offline
              xrok1
              isn't that what make unique does?
                That's what I'm curious about. There is no existing "make unique" method. So you can't single out a face, find its material and tell it to be unique.
                But you absolutely can find a face, find its material, find the path to that material. Then make a new material and assign the image to the new material. Perhaps the actual image would need to be copied as a separate file though. I just don't know. I think Thom might be out of town right now too. Mqabe someone else has some time to test this stuff out.
                Chris
                • X Offline
                  xrok1
                  well if someone does crack the case it would be nice to be able to do the same (multiple faces) with projected texture as well 😉
                    If I get this right you want a new method material.make_unique ?
                    If so I have something...
                    material-make_unique.rb adds a new Method to Sketchup's Material Class -
                    It makes a clone of the material from the original and gives it a
                    new name, incrementing the 'name' with #n at the end.
                    Returns a unique new material.
                    Example of use...
                    make material of selected faces unique
                    type makefacesmaterialsunique in the Ruby Console
                    No UV mapping yet...
                      The native make unique function doesn't simply makes a new material based on the one applied to a face but also
                      • crops the image on the face boundaries
                      • if it is a "tiling" image (more instances applied on a face obviously), it will "unite" those images into the unique image
                        I know... This was just a quick first attempt... The UV and size/merged images need work... 😒
                        • X Offline
                          xrok1
                          great progress! keep going 😄
                          are you going to throw the projected option in there too?? 😍
                            OK-OK, I wasn't going to "lesson" you (I was sure you know 😉 ) just mentioned to make it obvious for all.
                            Anyway, I think that the improved texturing tools in SU 7 are still undervalued by many.
                            • X Offline
                              xrok1
                              any progress? 😛
                                Sorry... it's at the end of a long list 😞 If anyone else wants to chip in pleased do...
                                • X Offline
                                  xrok1
                                  TIG, thanks for considering it and best luck with all your other projects. 😄
