    [req] unique texture
    15 Posts 5 Posters 2.8k Views 5 Watching
    • X Offline
      xrok1
      would anyone be able to do a script that would allow "Make Unique Texture" to be applied to multiple faces at once?
      this could be very handy and time saving when working with photomatch...
      • E Offline
        Ecuadorian
        Thomthom said the API didn't provide this function, but if the user sets a shortcut for this function (or any function for that matter) the API can trigger this shortcut. So perhaps you could change your Ruby request to:
        "Repeat shortcut over multiple faces"
        ...or something like that.
        -Miguel Lescano
        • X Offline
          xrok1
          or step through selection 😉
          whatever you call it, i'd call it handy!
          • Chris FullmerC Offline
            Thom's done more with materials than myself, but it seems like there might be some way to not do a simple .make_unique, but perhaps create a new texture from the existing. It seem slike it would require finding the original image, make a new material that uses the original image as the texture, then apply the new material to the face, using the previous UV coordinates.
            Is all of that possible?
            • X Offline
              xrok1
              isn't that what make unique does?
                That's what I'm curious about. There is no existing "make unique" method. So you can't single out a face, find its material and tell it to be unique.
                But you absolutely can find a face, find its material, find the path to that material. Then make a new material and assign the image to the new material. Perhaps the actual image would need to be copied as a separate file though. I just don't know. I think Thom might be out of town right now too. Mqabe someone else has some time to test this stuff out.
                • X Offline
                  xrok1
                  well if someone does crack the case it would be nice to be able to do the same (multiple faces) with projected texture as well 😉
                  • TIGT Online
                    If I get this right you want a new method material.make_unique ?
                    If so I have something...
                    material-make_unique.rb adds a new Method to Sketchup's Material Class -
                    It makes a clone of the material from the original and gives it a
                    new name, incrementing the 'name' with #n at the end.
                    Returns a unique new material.
                    Example of use...
                    make material of selected faces unique
                    type makefacesmaterialsunique in the Ruby Console
                    No UV mapping yet...
                      The native make unique function doesn't simply makes a new material based on the one applied to a face but also
                      • crops the image on the face boundaries
                      • if it is a "tiling" image (more instances applied on a face obviously), it will "unite" those images into the unique image
                      • TIGT Online
                        I know... This was just a quick first attempt... The UV and size/merged images need work... 😒
                        • X Offline
                          xrok1
                          great progress! keep going 😄
                          are you going to throw the projected option in there too?? 😍
                            OK-OK, I wasn't going to "lesson" you (I was sure you know 😉 ) just mentioned to make it obvious for all.
                            Anyway, I think that the improved texturing tools in SU 7 are still undervalued by many.
                            • X Offline
                              xrok1
                              any progress? 😛
                              • TIGT Online
                                Sorry... it's at the end of a long list 😞 If anyone else wants to chip in pleased do...
                                • X Offline
                                  xrok1
                                  TIG, thanks for considering it and best luck with all your other projects. 😄
