    [req] unique texture
    15 Posts 5 Posters 3.3k Views 5 Watching
    • X
      xrok1
      or step through selection ๐Ÿ˜‰
      whatever you call it, i'd call it handy!
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
      • Chris FullmerC
        Thom's done more with materials than myself, but it seems like there might be some way to not do a simple .make_unique, but perhaps create a new texture from the existing. It seem slike it would require finding the original image, make a new material that uses the original image as the texture, then apply the new material to the face, using the previous UV coordinates.
        Is all of that possible?
        • X
          xrok1
          isn't that what make unique does?
          • Chris FullmerC
            That's what I'm curious about. There is no existing "make unique" method. So you can't single out a face, find its material and tell it to be unique.
            But you absolutely can find a face, find its material, find the path to that material. Then make a new material and assign the image to the new material. Perhaps the actual image would need to be copied as a separate file though. I just don't know. I think Thom might be out of town right now too. Mqabe someone else has some time to test this stuff out.
            • X
              xrok1
              well if someone does crack the case it would be nice to be able to do the same (multiple faces) with projected texture as well ๐Ÿ˜‰
                If I get this right you want a new method material.make_unique ?
                If so I have something...
                material-make_unique.rb adds a new Method to Sketchup's Material Class -
                It makes a clone of the material from the original and gives it a
                new name, incrementing the 'name' with #n at the end.
                Returns a unique new material.
                Example of use...
                make material of selected faces unique
                type makefacesmaterialsunique in the Ruby Console
                No UV mapping yet...
                • GaieusG
                  The native make unique function doesn't simply makes a new material based on the one applied to a face but also
                  • crops the image on the face boundaries
                  • if it is a "tiling" image (more instances applied on a face obviously), it will "unite" those images into the unique image
                    I know... This was just a quick first attempt... The UV and size/merged images need work... ๐Ÿ˜’
                    • X
                      xrok1
                      great progress! keep going ๐Ÿ˜„
                      are you going to throw the projected option in there too?? ๐Ÿ˜
                      • GaieusG
                        OK-OK, I wasn't going to "lesson" you (I was sure you know ๐Ÿ˜‰ ) just mentioned to make it obvious for all.
                        Anyway, I think that the improved texturing tools in SU 7 are still undervalued by many.
                        • X
                          xrok1
                          any progress? ๐Ÿ˜›
                            Sorry... it's at the end of a long list ๐Ÿ˜ž If anyone else wants to chip in pleased do...
                            • X
                              xrok1
                              TIG, thanks for considering it and best luck with all your other projects. ๐Ÿ˜„
