    [req] unique texture
    15 Posts 5 Posters 3.3k Views 5 Watching
    • Chris FullmerC
      Thom's done more with materials than myself, but it seems like there might be some way to not do a simple .make_unique, but perhaps create a new texture from the existing. It seem slike it would require finding the original image, make a new material that uses the original image as the texture, then apply the new material to the face, using the previous UV coordinates.
      Is all of that possible?
      • X
        xrok1
        isn't that what make unique does?
        • Chris FullmerC
          That's what I'm curious about. There is no existing "make unique" method. So you can't single out a face, find its material and tell it to be unique.
          But you absolutely can find a face, find its material, find the path to that material. Then make a new material and assign the image to the new material. Perhaps the actual image would need to be copied as a separate file though. I just don't know. I think Thom might be out of town right now too. Mqabe someone else has some time to test this stuff out.
          • X
            xrok1
            well if someone does crack the case it would be nice to be able to do the same (multiple faces) with projected texture as well πŸ˜‰
              If I get this right you want a new method material.make_unique ?
              If so I have something...
              material-make_unique.rb adds a new Method to Sketchup's Material Class -
              It makes a clone of the material from the original and gives it a
              new name, incrementing the 'name' with #n at the end.
              Returns a unique new material.
              Example of use...
              make material of selected faces unique
              type makefacesmaterialsunique in the Ruby Console
              No UV mapping yet...
              • GaieusG
                The native make unique function doesn't simply makes a new material based on the one applied to a face but also
                • crops the image on the face boundaries
                • if it is a "tiling" image (more instances applied on a face obviously), it will "unite" those images into the unique image
                  I know... This was just a quick first attempt... The UV and size/merged images need work... πŸ˜’
                  • X
                    xrok1
                    great progress! keep going πŸ˜„
                    are you going to throw the projected option in there too?? 😍
                    • GaieusG
                      OK-OK, I wasn't going to "lesson" you (I was sure you know πŸ˜‰ ) just mentioned to make it obvious for all.
                      Anyway, I think that the improved texturing tools in SU 7 are still undervalued by many.
                      • X
                        xrok1
                        any progress? πŸ˜›
                          Sorry... it's at the end of a long list 😞 If anyone else wants to chip in pleased do...
                          • X
                            xrok1
                            TIG, thanks for considering it and best luck with all your other projects. πŸ˜„
