    [Plugin] 2 Faces + Path ver. 1.5.
    72 Posts 48 Posters 80.1k Views 48 Watching
    • B
      balloon
      Thank you very much!
      • M
        museummaker
        I am having some difficulty with this shape. It is a spiral with a shape, and it tapers as it it travels down the spiral.
        I thought this plug would work but I am getting odd results.
        Any ideas?
        Thank you for all,
        tryagain.skp
          Use the Perpendicular face tool by Chris Fullmer for put your 2 faces at the extremities of the curve!
          Don't take care of their positions explode the groups select all
          and launch 2 faces + path 😉
          • M
            museummaker
            Hi Frenchy,
            I used that when I set up the model. Also tried flipping the normals on the shaped ends, various options in the dialog box, its not behaving like I thought. Driving me crazy
              Maybe it's your curve! I have drawn a new one 😉
              With spiral 1.3
              • M
                museummaker
                I was guessing it may be that the spiral was precisely formed.
                I'm trying but I still can't get it.
                • M
                  museummaker
                  I got it! ☀
                  Used Shape Bender instead!
                  • brookefoxB
                    brookefox
                    Thank you much, Kirill.
                    I'm trying to get up to speed. Not being a ruby cooker, I am ignorant of why a straight 'curve' is needed rather than an edge, multi- segmented or not, though you clearly state that a curve path is what is required. I wish error messages could be generated to help users, say if they make selection errors. Or perhaps that the plug be made to work with edge paths, so slow-witted users wouldn't need error messages.... So much.
                    ~ Brooke
                    • K
                      kirill2008
                      You may try new version of 'LSS Toolbar' instead of '2 Faces + Path' plugin.
                      New version of 'LSS Toolbar' is still under construction, but fortunately '2 faces + path' tool is already implemented and work even more stable, than '2 Faces + Path ver. 1.5' stand-alone plugin.
                      You may take a look at demonstration video at https://sites.google.com/site/lssoft2011/home/lss-toolbar
                      lss_toolbar_2_0_pre_alpha.zip
                        Interesting, Kirill. The first try gave me this result. I would expect a smoother transition from the circle to the lozenge shape. Any suggestions on a way to make the transition correctly?
                        • K
                          kirill2008
                          Yes you can use 2 command buttons within '2 Faces + Path' section of web-dialog:
                          • Flip face normal
                          • Rotate face to dock vertices with other face
                            It is also possible to fix the situation after 'pathface entity' generation: you can rotate any of two faces manually and refresh 'pathface entity'.
                            I promise, that I'll write some manuals after 'LSS Toolbar' functionality update completion.
                          • irwanwrI
                            irwanwr
                            looks and sounds good.
                            been waiting for the new LSS Toolbar.
                            thank you kirill.
                            • 4 / 4
