    [Plugin] 2 Faces + Path ver. 1.5.
    72 Posts 48 Posters 79.1k Views 48 Watching
    • ken28875K Offline
      ken28875
      @kirill2008 said:
      @ken28875 said:
      This is an issue 😞 I'll try to fix it.
      Thanks, Kirill! Looking forward to the updated plugin. Take care.
      Follow Your Dreams.
      • H Offline
        hsjzyangbin
        Hi,ken28875,I want 2 face+path give path just like this:
        • ken28875K Offline
          ken28875
          Hi hsjyangbin,
          I think you meant to ask Kirill. He's the one who wrote the plugin.
          I have no idea about code. lol
          _KN
          Follow Your Dreams.
            romain210
            thanks a lot
              Seems there is a little glitch ! 😮
              Don't works for all these sort of "pierced faces" !
              CLick if scrollbars
                balloon
                Thank you very much!
                  museummaker
                  I am having some difficulty with this shape. It is a spiral with a shape, and it tapers as it it travels down the spiral.
                  I thought this plug would work but I am getting odd results.
                  Any ideas?
                  Thank you for all,
                  tryagain.skp
                    Use the Perpendicular face tool by Chris Fullmer for put your 2 faces at the extremities of the curve!
                    Don't take care of their positions explode the groups select all
                    and launch 2 faces + path 😉
                      museummaker
                      Hi Frenchy,
                      I used that when I set up the model. Also tried flipping the normals on the shaped ends, various options in the dialog box, its not behaving like I thought. Driving me crazy
                        Maybe it's your curve! I have drawn a new one 😉
                        With spiral 1.3
                          museummaker
                          I was guessing it may be that the spiral was precisely formed.
                          I'm trying but I still can't get it.
                            museummaker
                            I got it! ☀
                            Used Shape Bender instead!
                            • brookefoxB Offline
                              brookefox
                              Thank you much, Kirill.
                              I'm trying to get up to speed. Not being a ruby cooker, I am ignorant of why a straight 'curve' is needed rather than an edge, multi- segmented or not, though you clearly state that a curve path is what is required. I wish error messages could be generated to help users, say if they make selection errors. Or perhaps that the plug be made to work with edge paths, so slow-witted users wouldn't need error messages.... So much.
                              ~ Brooke
                                kirill2008
                                You may try new version of 'LSS Toolbar' instead of '2 Faces + Path' plugin.
                                New version of 'LSS Toolbar' is still under construction, but fortunately '2 faces + path' tool is already implemented and work even more stable, than '2 Faces + Path ver. 1.5' stand-alone plugin.
                                You may take a look at demonstration video at https://sites.google.com/site/lssoft2011/home/lss-toolbar
                                lss_toolbar_2_0_pre_alpha.zip
                                  Interesting, Kirill. The first try gave me this result. I would expect a smoother transition from the circle to the lozenge shape. Any suggestions on a way to make the transition correctly?
                                    kirill2008
                                    Yes you can use 2 command buttons within '2 Faces + Path' section of web-dialog:
                                    • Flip face normal
                                    • Rotate face to dock vertices with other face
                                      It is also possible to fix the situation after 'pathface entity' generation: you can rotate any of two faces manually and refresh 'pathface entity'.
                                      I promise, that I'll write some manuals after 'LSS Toolbar' functionality update completion.
                                    • irwanwrI Offline
                                      irwanwr
                                      looks and sounds good.
                                      been waiting for the new LSS Toolbar.
                                      thank you kirill.
                                      • 4 / 4
