    [Plugin] 2 Faces + Path ver. 1.5.
    72 Posts 48 Posters 79.2k Views 48 Watching
      It's works for me because I use an oldest version 😉
        kirill2008
        @ken28875 said:
        Hmm..ok, so I tried it and here's what I got.
        Any ideas why? Thanks.
        Hi, Ken.
        This is an issue 😞 I'll try to fix it. The problem is that "Process closest distances" method works good only for faces bounded by convex polygons. You may try "Process nearest indices" shape morphing option, but it sometimes causes inside-outs.
        "Process nearest indices" method does not depend on face bound topology.
        BTW, if someone try to process faces with more complex topology (I mean, faces with internal holes), then plugin will also fail to make an appropriate morphing, regardless of chosen shape morphing option.
        For example we have 2 faces: 1-st has circular outer loop and 3 square internal holes, 2-nd has square outer loop and 2 circular internal holes. Well... I must say, the decision what kind of morphing would be more appropriate becomes pretty unobvious 😉 . But I think that such task (the above mentioned example) is very exotic one and has no practical utilization.
          boilingsnow
          perfect!
          thank you so much!
          • ken28875K Offline
            ken28875
            @kirill2008 said:
            Thanks, Kirill! Looking forward to the updated plugin. Take care.
            Follow Your Dreams.
            • H Offline
              hsjzyangbin
              Hi,ken28875,I want 2 face+path give path just like this:
              • ken28875K Offline
                ken28875
                Hi hsjyangbin,
                I think you meant to ask Kirill. He's the one who wrote the plugin.
                I have no idea about code. lol
                _KN
                Follow Your Dreams.
                  romain210
                  thanks a lot
                    Seems there is a little glitch ! 😮
                    Don't works for all these sort of "pierced faces" !
                    CLick if scrollbars
                      balloon
                      Thank you very much!
                        museummaker
                        I am having some difficulty with this shape. It is a spiral with a shape, and it tapers as it it travels down the spiral.
                        I thought this plug would work but I am getting odd results.
                        Any ideas?
                        Thank you for all,
                        tryagain.skp
                          Use the Perpendicular face tool by Chris Fullmer for put your 2 faces at the extremities of the curve!
                          Don't take care of their positions explode the groups select all
                          and launch 2 faces + path 😉
                            museummaker
                            Hi Frenchy,
                            I used that when I set up the model. Also tried flipping the normals on the shaped ends, various options in the dialog box, its not behaving like I thought. Driving me crazy
                              Maybe it's your curve! I have drawn a new one 😉
                              With spiral 1.3
                                museummaker
                                I was guessing it may be that the spiral was precisely formed.
                                I'm trying but I still can't get it.
                                  museummaker
                                  I got it! ☀
                                  Used Shape Bender instead!
                                  • brookefoxB Offline
                                    brookefox
                                    Thank you much, Kirill.
                                    I'm trying to get up to speed. Not being a ruby cooker, I am ignorant of why a straight 'curve' is needed rather than an edge, multi- segmented or not, though you clearly state that a curve path is what is required. I wish error messages could be generated to help users, say if they make selection errors. Or perhaps that the plug be made to work with edge paths, so slow-witted users wouldn't need error messages.... So much.
                                    ~ Brooke
                                      kirill2008
                                      You may try new version of 'LSS Toolbar' instead of '2 Faces + Path' plugin.
                                      New version of 'LSS Toolbar' is still under construction, but fortunately '2 faces + path' tool is already implemented and work even more stable, than '2 Faces + Path ver. 1.5' stand-alone plugin.
                                      You may take a look at demonstration video at https://sites.google.com/site/lssoft2011/home/lss-toolbar
                                      lss_toolbar_2_0_pre_alpha.zip
                                        Interesting, Kirill. The first try gave me this result. I would expect a smoother transition from the circle to the lozenge shape. Any suggestions on a way to make the transition correctly?
                                          kirill2008
                                          Yes you can use 2 command buttons within '2 Faces + Path' section of web-dialog:
                                          • Flip face normal
                                          • Rotate face to dock vertices with other face
                                            It is also possible to fix the situation after 'pathface entity' generation: you can rotate any of two faces manually and refresh 'pathface entity'.
                                            I promise, that I'll write some manuals after 'LSS Toolbar' functionality update completion.
                                          • irwanwrI Offline
                                            irwanwr
                                            looks and sounds good.
                                            been waiting for the new LSS Toolbar.
                                            thank you kirill.
                                            • 4 / 4
