    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 225.7k Views 52 Watching
      congellous
      There doesn't seem to be an extension in there ?
      It has instal extension which one is the extension ?
          congellous
          Yeah it's not there
            In your list there's 'GhostComp%201' what's that ?
            Looks like an html based name ?
            There ought to be a folder called 'GHOSTCOMP_Dir_10'
            containing these files Capture.PNG This suggests you has mis-installed it...
              congellous
              Dunno what that was but removing it sorted it, didn't even need to turn the extension on. Thanks TIG
              • P Offline
                parsleybrain
                Hello Fredo, thanks for another great plugin. So I startet to use it and it worked just fine. I've lots of railings in my model, some are just copies of components but I also had to make a bunch of them unique and to tweak them. Finally making even one copy of an component took so long I decided to use your ghostcomp. And it worked - but now Sketchup always chrashes when I try to create a ghost component. Do you have any advice or idea what to do about that? Thanks in advance.
                • fredo6F Offline
                  fredo6
                  Please make sure you have the most recent versions. For the crash, it may be some conflicting plugins (some versions of Vray and Podium for instance)
                  Fredo
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: GhostComp v1.1a - 27 Nov 13
                    GhostComp 1.1a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                    See main post of this thread for Download.
                    Fredo
                      jaceguay
                      Really useful, many thanks.
                      • ppoublanP Offline
                        ppoublan
                        @fredo6 said:
                        The concept behind GhostComp is to associate a simplified version to a component (called Ghost). Then the script provides an easy way to switch back and forth between the Ghost version and the Real version in the model.
                        Hi Fredo,
                        I integrated this concept into the last version of 3D Tree Maker, with a function that could be called by external plugins to switch/and back from full view to proxy view. the good thing is that in proxy view only object information needed to rebuild the object is kept in object dictionary, not all the real edges/faces.
                        If you think it could be interesting to integrate calls to 3DTreeMaker from your plugin, let me know.
                        Yours
                        pascal
                        • fredo6F Offline
                          fredo6
                          Sure. Thanks for thinking about GhostComp
                          I would need to revisit this plugin, but it is a good idea to integrate custom ghost for certain kind of components.
                          I'll have a look and advise.
                          Fredo
                          • ppoublanP Offline
                            ppoublan
                            Things to know before calling :
                            • those functions contain purge of unused component definitions and unused materials (after drawing a tree or its proxy). So to be called outside of a loop browsing each component definition, and list of definitions to be rebuild if needed after calling.
                            • it contains start/commit, I do not know results of nesting multiple start/commit, so preferably call outside of start/commit.
                              Needs v1.10 at least (not implemented in previous versions).
                            Did not tested, but this should work :
                            #To switch all trees to proxies
                            if file_loaded?('3darcstudiotreemain.rb’)
                            M3darcstudiotree.f3das_changealltoproxies
                            #To switch all proxies to trees
                            if file_loaded?(β€˜3darcstudiotreemain.rb’)
                            M3darcstudiotree.f3das_redrawall
                            • danchoD Offline
                              dancho
                              Fredo6 I like your plugin but with SU2014 on windows7 I can't change
                              from bounding box to wireframe mode, its always bounding box. Any suggestion?
                              Sorry, I found a solution. First must to choose a type than create
                              ghost and turn it on. Perfect πŸ˜†
                              • fredo6F Offline
                                fredo6
                                NEW RELEASE: GhostComp v1.2a - 20 Oct 14
                                GhostComp 1.2a is required for the support of usernames with non-ascii characters in Sketchup 2014.
                                Fredo
                                  salamon
                                  Hello is this working for sketchup 2015?
                                    rv1974
                                    I wish there was a-la multiscatter point display (maybe instead of points which can be accidentally deleted with 'Delete Guides' small tiny lines could make the same task). πŸ˜’
                                      @mrcitybuilder said:
                                      Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.
                                      Why didn't you get the RBZ from the PluginStore, then install that ?
                                      Unzipping olde things and messing up with the results' installation went long ago - with v7...
                                      Ensure you have the latest LibFredo:
                                      http://sketchucation.com/pluginstore?pln=LibFredo6
                                      and then GhostComp:
                                      http://sketchucation.com/pluginstore?pln=GhostComp
                                        MrCityBuilder
                                        (Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.)
                                        SOLVED 😎
                                          MrCityBuilder
                                          Yeah, thanks - that did the trick. Ghostcomp now fully functional!
                                            lyvananhtoyo
                                            thank very much. this help me to avoid the situation some imported component is much bigger than my model and make SU become very slow.
                                            • 6
                                            • 4 / 6
