    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 217.1k Views 52 Watching
    • fredo6F Offline
      @parsleybrain said:
      Hello Fredo, thanks for another great plugin. So I startet to use it and it worked just fine. I've lots of railings in my model, some are just copies of components but I also had to make a bunch of them unique and to tweak them. Finally making even one copy of an component took so long I decided to use your ghostcomp. And it worked - but now Sketchup always chrashes when I try to create a ghost component. Do you have any advice or idea what to do about that? Thanks in advance.
      Please make sure you have the most recent versions. For the crash, it may be some conflicting plugins (some versions of Vray and Podium for instance)
      • fredo6F Offline
        NEW RELEASE: GhostComp v1.1a - 27 Nov 13
        GhostComp 1.1a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
          jaceguay
          Really useful, many thanks.
          • ppoublanP Offline
            ppoublan
            @fredo6 said:
            The concept behind GhostComp is to associate a simplified version to a component (called Ghost). Then the script provides an easy way to switch back and forth between the Ghost version and the Real version in the model.
            Hi Fredo,
            I integrated this concept into the last version of 3D Tree Maker, with a function that could be called by external plugins to switch/and back from full view to proxy view. the good thing is that in proxy view only object information needed to rebuild the object is kept in object dictionary, not all the real edges/faces.
            If you think it could be interesting to integrate calls to 3DTreeMaker from your plugin, let me know.
            Yours
            pascal
            • fredo6F Offline
              Sure. Thanks for thinking about GhostComp
              I would need to revisit this plugin, but it is a good idea to integrate custom ghost for certain kind of components.
              I'll have a look and advise.
              • ppoublanP Offline
                ppoublan
                Things to know before calling :
                • those functions contain purge of unused component definitions and unused materials (after drawing a tree or its proxy). So to be called outside of a loop browsing each component definition, and list of definitions to be rebuild if needed after calling.
                • it contains start/commit, I do not know results of nesting multiple start/commit, so preferably call outside of start/commit.
                  Needs v1.10 at least (not implemented in previous versions).
                Did not tested, but this should work :
                #To switch all trees to proxies
                if file_loaded?('3darcstudiotreemain.rb’)
                M3darcstudiotree.f3das_changealltoproxies
                #To switch all proxies to trees
                if file_loaded?(‘3darcstudiotreemain.rb’)
                M3darcstudiotree.f3das_redrawall
                • danchoD Offline
                  dancho
                  Fredo6 I like your plugin but with SU2014 on windows7 I can't change
                  from bounding box to wireframe mode, its always bounding box. Any suggestion?
                  Sorry, I found a solution. First must to choose a type than create
                  ghost and turn it on. Perfect 😆
                  • fredo6F Offline
                    NEW RELEASE: GhostComp v1.2a - 20 Oct 14
                    GhostComp 1.2a is required for the support of usernames with non-ascii characters in Sketchup 2014.
                      salamon
                      Hello is this working for sketchup 2015?
                        rv1974
                        I wish there was a-la multiscatter point display (maybe instead of points which can be accidentally deleted with 'Delete Guides' small tiny lines could make the same task). 😒
                          @mrcitybuilder said:
                          Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.
                          Why didn't you get the RBZ from the PluginStore, then install that ?
                          Unzipping olde things and messing up with the results' installation went long ago - with v7...
                          Ensure you have the latest LibFredo:
                          http://sketchucation.com/pluginstore?pln=LibFredo6
                          and then GhostComp:
                          http://sketchucation.com/pluginstore?pln=GhostComp
                            MrCityBuilder
                            (Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.)
                            SOLVED 😎
                              MrCityBuilder
                              Yeah, thanks - that did the trick. Ghostcomp now fully functional!
                                lyvananhtoyo
                                thank very much. this help me to avoid the situation some imported component is much bigger than my model and make SU become very slow.
                                  mwm5053
                                  Within the last month I installed Ghost Comp from the Sketchucation Plugin Store so I believe I have the latest ver.
                                  Great plugin works great but after hiding a GC I noticed it won't change back to regular comp. not sure why. Tried everything I could think of. Any help would be appreciated Thanks
                                  I apologize if this has been addressed already.
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                    mwm5053
                                    I guess I should further explain what I did. I had a large component of grass that contained nested comps of grass to move and copy at one point I hide the GC while in GC visibility (cube) mode but when i unhide it, it would not return to regular comp.
                                    2011 iMac
                                    V2 Twilight
                                    • duanekempD Offline
                                      duanekemp
                                      Haven't tested yet, but... is this up-to-date with SU 2018?
                                      Duane Kemp
                                      Kemp Productions
                                      Puidoux, Switzerland
                                      Gallery:
                                      https://duanekemp.artstation.com/
                                      • fredo6F Offline
                                        Should work with SU2018.
                                        Make some tests with it before going to large models, and always keep a safe copy somewhere.
                                          duanekemp
                                          Thanks, will give it a go. As well, will share this in my FB groups to revive it. I had never heard of this before. Sounds like a practical plugin to have.
                                          Duane Kemp
                                          Kemp Productions
                                          Gallery:
                                            rv1974
                                            Fredo, may I humbly request an extra option for 2d squares instead of cubes?
                                            • 4 / 6
