    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 217.8k Views 52 Watching
    • fredo6F Offline
      NEW RELEASE: GhostComp v1.1a - 27 Nov 13
      GhostComp 1.1a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
        jaceguay
        Really useful, many thanks.
        • ppoublanP Offline
          ppoublan
          @fredo6 said:
          The concept behind GhostComp is to associate a simplified version to a component (called Ghost). Then the script provides an easy way to switch back and forth between the Ghost version and the Real version in the model.
          Hi Fredo,
          I integrated this concept into the last version of 3D Tree Maker, with a function that could be called by external plugins to switch/and back from full view to proxy view. the good thing is that in proxy view only object information needed to rebuild the object is kept in object dictionary, not all the real edges/faces.
          If you think it could be interesting to integrate calls to 3DTreeMaker from your plugin, let me know.
          Yours
          pascal
          • fredo6F Offline
            Sure. Thanks for thinking about GhostComp
            I would need to revisit this plugin, but it is a good idea to integrate custom ghost for certain kind of components.
            I'll have a look and advise.
            • ppoublanP Offline
              ppoublan
              Things to know before calling :
              • those functions contain purge of unused component definitions and unused materials (after drawing a tree or its proxy). So to be called outside of a loop browsing each component definition, and list of definitions to be rebuild if needed after calling.
              • it contains start/commit, I do not know results of nesting multiple start/commit, so preferably call outside of start/commit.
                Needs v1.10 at least (not implemented in previous versions).
              Did not tested, but this should work :
              #To switch all trees to proxies
              if file_loaded?('3darcstudiotreemain.rb’)
              M3darcstudiotree.f3das_changealltoproxies
              #To switch all proxies to trees
              if file_loaded?(‘3darcstudiotreemain.rb’)
              M3darcstudiotree.f3das_redrawall
              • danchoD Offline
                dancho
                Fredo6 I like your plugin but with SU2014 on windows7 I can't change
                from bounding box to wireframe mode, its always bounding box. Any suggestion?
                Sorry, I found a solution. First must to choose a type than create
                ghost and turn it on. Perfect 😆
                • fredo6F Offline
                  NEW RELEASE: GhostComp v1.2a - 20 Oct 14
                  GhostComp 1.2a is required for the support of usernames with non-ascii characters in Sketchup 2014.
                    salamon
                    Hello is this working for sketchup 2015?
                      rv1974
                      I wish there was a-la multiscatter point display (maybe instead of points which can be accidentally deleted with 'Delete Guides' small tiny lines could make the same task). 😒
                        @mrcitybuilder said:
                        Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.
                        Why didn't you get the RBZ from the PluginStore, then install that ?
                        Unzipping olde things and messing up with the results' installation went long ago - with v7...
                        Ensure you have the latest LibFredo:
                        http://sketchucation.com/pluginstore?pln=LibFredo6
                        and then GhostComp:
                        http://sketchucation.com/pluginstore?pln=GhostComp
                          MrCityBuilder
                          (Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.)
                          SOLVED 😎
                            MrCityBuilder
                            Yeah, thanks - that did the trick. Ghostcomp now fully functional!
                              lyvananhtoyo
                              thank very much. this help me to avoid the situation some imported component is much bigger than my model and make SU become very slow.
                                mwm5053
                                Within the last month I installed Ghost Comp from the Sketchucation Plugin Store so I believe I have the latest ver.
                                Great plugin works great but after hiding a GC I noticed it won't change back to regular comp. not sure why. Tried everything I could think of. Any help would be appreciated Thanks
                                I apologize if this has been addressed already.
                                2011 iMac
                                SU 2015 Pro, 2017 Make
                                V2 Twilight
                                macOS Sierra 10.12.5
                                  mwm5053
                                  I guess I should further explain what I did. I had a large component of grass that contained nested comps of grass to move and copy at one point I hide the GC while in GC visibility (cube) mode but when i unhide it, it would not return to regular comp.
                                  2011 iMac
                                  V2 Twilight
                                  • duanekempD Offline
                                    duanekemp
                                    Haven't tested yet, but... is this up-to-date with SU 2018?
                                    Duane Kemp
                                    Kemp Productions
                                    Puidoux, Switzerland
                                    Gallery:
                                    https://duanekemp.artstation.com/
                                    • fredo6F Offline
                                      Should work with SU2018.
                                      Make some tests with it before going to large models, and always keep a safe copy somewhere.
                                        duanekemp
                                        Thanks, will give it a go. As well, will share this in my FB groups to revive it. I had never heard of this before. Sounds like a practical plugin to have.
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                          rv1974
                                          Fredo, may I humbly request an extra option for 2d squares instead of cubes?
                                          • jujuJ Offline
                                            juju
                                            Like CADup or just plain blank 2D squares / rectangles?
                                            • 4 / 6
