    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 217.8k Views 52 Watching
    • fredo6F Offline
      fredo6
      INFORMATION: there is a new extension, called FredoGhost, which provides a more generic and customizable framework for Proxies. Here is the main thread for FredoGhost. Note that FredoGhost supports only SU2017 and above.
      **%(#008000)[# Permission to use this software for any purpose and without fee is hereby granted
      Distribution of this software for any purpose is subject to:
      - the expressed, written consent of the author
      - the inclusion of the present copyright notice in all copies.]**
      Please UPGRADE to this latest version 1.4 if you run SU 2018.
      http://forums.sketchucation.com/download/file.php?id=49290
      The concept behind GhostComp is to associate a simplified version to a component (called Ghost). Then the script provides an easy way to switch back and forth between the Ghost version and the Real version in the model. The idea is that in many situations, switching heavy and complex components to their Ghost version would make the model view lighter to manipulate during the design phase (for orbiting, copying, etc…).
      Note: I just realized that the concept had been introduced independently, but earlier, by AdamB, under the name of Proxy, in his LightUp plugin. So, I wanted everyone to know.
      This is an experimental concept, and frankly, I don’t know if it really fits any practical design workflow with high-poly models. If it does, then I think it should better be implemented in the native Sketchup application than in Ruby (if the Google SU team has time of course).
      In version 1.1, the ‘simplified’ Ghost version can be generated as:
      • the Bounding Box of the top level component(so just 6 faces)
      • the Bounding Boxes of the top level component and its subcomponents, hierarchically
      • a Wireframeof the component
      • a Simplified copy of the component(keeping a limited number of the largest faces)
      • a Frozen copy of the component(useful before performing poly-greedy transformation such as RoundCorner or Subdivide & Smooth)
      Under the cover, GhostComp uses a hidden layer to maintain copies of the original components and their Ghost versions. Unfortunately, as there is no way to hide component definitions, you’ll see the Ghost component definitions in the Component browser. Note that GhostComp does not touch, modify or delete the original components.
      http://forums.sketchucation.com/download/file.php?id=49286
      GhostComp - Quickcard - English - v1.1 - 27 Nov 13.pdf
      Just drop the attached PDF file into the SU Plugins directory to have it accessible from within Sketchup.
      • Sketchup: v6 to SU2018 – works better with v8 M2 and above
      • Platform: Windows and Mac
      • Language: English, French, Chinese
      • Menus: by default, it is installed in Tools > Fredo6 Collection > GhostComp
      • Icon toolbar: by Default ‘Ghost Comp. At first installation all 10 icons are shown. You can then configure which icon you wish to include in the toolbar from the Default Parameters…).
        There is an alternative toolbar by DJMX1
      • The plugin is free, for private and commercial usage. There is a donation menu however.
      http://forums.sketchucation.com/download/file.php?id=49287
      There are now multiple ways to install scripts
      • SCF Plugin Store (SU8 and SU13) - recommended method
      • Unzip (all SU versions and for installations in an alternate Plugins directory)
      • Extension Manager with RBZ files (SU8 and SU13)
      Whatever way you install, you must end up with the following footprint:
      The standard SU Plugins root directories are:
      Windows SU8: C:\Program Files\Google\Google SketchUp 8\Plugins
      Windows SU13: C:\Program Files\SketchUp\SketchUp 2013/Plugins
      Windows SU14: C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
      Mac SU8: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
      Mac SU13: ~/Library/Application Support/SketchUp 2013/SketchUp/Plugins
      Mac SU14: ~/Library/Application Support/SketchUp 2014/SketchUp/Plugins
      CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
      http://forums.sketchucation.com/download/file.php?id=49285
      If you run SU8, SU13 or SU14, the strongly recommended installation method is to Autoinstall with the SCF Plugin Store tool.
      Otherwise, you can download the GhostComprbz file from the Plugin Store page for GhostComp.
      IMPORTANT: Requires to download LibFredo6 8.6 or higher if not already installed
      **Note for SU6 and SU7 users, download the rbz file from the plugin store page, and change its extension from .rbz to .zip
      Then:
      1. Open the zip archive
      2. Select All (Ctrl A)
      3. Extract into the Sketchup Plugin Directory
      4. Answer YES to OVERWRITE all existing files if any
      5. Make sure you get the correct footprint (one rb file and one folder)**
        CONFLICTING PLUGINS: some plugins conflicts with some of my scripts
      • Some versions of Podium
      • SunPosition
      • Matchbox
      http://forums.sketchucation.com/download/file.php?id=49284
      Here is a video showing GhostComp in action.
      [flash=425,344:2zqt7gcv]http://www.youtube.com/v/XZqTEQuEoLk&hl=en[/flash:2zqt7gcv]
      http://forums.sketchucation.com/download/file.php?id=49289
      GhostComp 1.4a – 31 Oct 18: Maintenance release and certification SU2018
      GhostComp 1.3a – 13 Nov 15: Maintenance release
      GhostComp 1.2a – 20 Oct 14: Release for non-ascii usernames
      GhostComp 1.1a – 27 Nov 13: Release for future Sketchup Compatibility
      GhostComp 1.0a – 26 Nov 09: Initial public release
      • K Offline
        Khai
        thankee 💚
        • H Offline
          howardhong
          VERY big,big thanks.
          • N Offline
            nomeradona
            ha! to help SU with viewing efficiently and quickly whne having all this heavy components... clever. thank u.
            visit my blog: http://www.nomeradona.blogspot.com
            • Rich O BrienR Online
              Thanks Fredo,
              This is a great plugin and i've looked forward to it since the video went up on Youtube. Finally i get to use it and it rocks
              rgds
              Rich
                DJMX1
                Super plugin fredo. merci.
                Par contre la transformation en fil de fer, ou la dégradation progressive, sont très longue dès que l'objet dépasse les 200ko (voir même plantage !)
                Si tu as une solution.
                J'avais fait un post sur le bounding box, et je ne sais pas si toi tu est capable de le faire, j'aurais voulu un plugin qui me permette d'activer une vue type
                bounding box, comme quand le fichier est trop lourd et que sketchup dégrade l'image en remplaçant les objet par des bounding box. C'est pas la même utilisation que GHOSTCOMP, et ça m'aurait bien rendu service.
                Dans l'attente. @+
                • MALAISEM Offline
                  MALAISE
                  Fantastic tool, for huge projects
                  Merci Fredo, I try it this evening
                  MALAISE
                  • fredo6F Offline
                    fredo6
                    Wireframe and Simplify options are rather for components that are not too complex, but would be repeated hundreds times in the model.
                    In this version 1.0, I did not optimize the generation of Ghosts actually, as my primary goal was to understand whether the concept would be useful.
                    Dans l'attente.
                    You can generate a Bounding Box Ghost for all objects (do a Select All before generation). The problem is to have a view where Ghosts are activated while in other views they are not.
                    This again underlines that it should be the SU Team integrating this type of dual appearance concept in the native Sketchup application. In Ruby script, there are too many limitations to make something clean, fast, safe and transparent to the model (i.e. without creating tons of hidden components, use a hidden layer, ...).
                    Fredo
                    • K Offline
                      kwistenbiebel
                      Fantastic Fredo!!
                      This is a plugin I will use very often (always?). finally a way to keep on editing those high poly scenes (trees, etc...).
                      I agree that a feature like this should be standard SU stuff, but I am glad you made it into a plugin.
                      Thanks. Much appreciated
                      • N Offline
                        notareal
                        👍 A keeper.
                        • I Offline
                          ideas_arte
                          Wow !!!!! did not the boys at Google, you did!
                          Greatly appreciated, I will be testing and commenting
                          Thanx!! Thanx!! Thanx!! Thanx!!
                          http://www.addemoticons.com/emoticon/animated/AddEmoticons04230.gif
                          http://www.addemoticons.com/emoticon/animated/AddEmoticons04213.gif
                          Greetings.
                            Bigre 😲 ☀ 😎
                            • W Offline
                              Whaat
                              Another winner Fredo! I had a similar idea once but never got to implementing it. I also wanted to mention that I have been using your Round Corner script lately and it is incredible! Great work!
                              • fredo6F Offline
                                fredo6
                                Thanks Dale. It shows that the Google SU team should have a closer look to what they could do natively in the Sketchup application, as this could be a useful complement to their quest for high-poly support.
                                Fredo
                                • urgenU Offline
                                  urgen
                                  ...thanks FREDO!...briliant! 👍 👍 👍 😄
                                  --pupil forever...------
                                  • P Offline
                                    Pg09
                                    Thank You!
                                    • StinkieS Offline
                                      Stinkie
                                      Oooh, this one's going to come in very handy indeed. Thanks!
                                      • W Offline
                                        wsms
                                        it works really good!
                                        this function shall be put in a new version of su
                                        • erikBE Offline
                                          erikB
                                          Thanks Fredo for this very handy pluging.
                                          Much appreciated ! 👍
                                          greetings, erikB
                                            DJMX1
                                            je poste mon petit pack d'icônes pour GHOSTCOMP. J'ai fait ça pour moi et je partage.
                                            http://img2.pict.com/16/93/89/1543527/0/ghostcompv1.png
                                            prendre les icônes et les copiées dans le dossier "IMAGES_Standard" du plugin GHOSTCOMP
                                            http://www.box.net/shared/gv8ooblvog
                                            • 6
                                            • 2 / 6
