    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 227.5k Views 52 Watching
    • troyhomeT
      troyhome
      You're some kind of SketchUp Santa Claus! Thank You
      IOviz.com
      SU Pro 2024 PC
        stegagG
        What is the message in SU7 :
        Loading file error GhostCompAlgo.rb
        uninitialized constant GhostComp::T6Errore di caricamento del file GhostCompLoader.rb
        • fredo6F
          It looks like a problem of installation, most probably your Unzip programs not reconstructing the folder hierarchy.
          Check out the footprint of files and folder in the post and in the documentation.
          It seems that some users have this type of problem.
          By curiosity, which utility do you use to unzip the files?
            stegagG
            Sorry, but I have dome an error of unzip
            Hi.
            • L
              latence
              Fredo THANK YOU for all your great work!
              • fredo6F
                The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
                see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=21469&hilit=plugin#p180536
                  aea
                  No working GHOSTCOMP ?
                  • Chris FullmerC
                    Perhaps you have a group selected instead of a component?
                      Ruturaj
                      Hi Fredo,
                      Thanks you very much ................... 😍
                      Thanks,
                      RuturaJ
                        aea
                        YES , WORKING , THANKS .
                        • X
                          xrok1
                          a perfect companion to fur. πŸ˜„ no? πŸ˜•
                          • X
                            xrok1
                            is there a reason this plug hides the geometry as well as the layer? if it just hid the layer one could use wireframe ghost but still render it, but with the geometry being hidden too it doesn't work that way. 😒 any work around for this?
                              Magnus123
                              Hi Fredo thanks for this awesome plugin! i have a question.... first mi render motor is vray, when i turn a component into a ghost, when i render the components it just a cube a surface or anything depending of the component, theres no way to render the original component being a ghost? the case is that i dont want to render the geometry that the plugins does, only the original component....thank you very much!
                                No - there is no proxy function in VfSU. Yet!
                                  Magnus123
                                  πŸ˜‰ ok thom thanks for answering mate! i hope that, Yet! its very soon it would be very good! God bless you and thanks for everything!
                                    Starling75
                                    Hi, when I try to copy/paste a component + its ghost component generated in a file "1" into another file, it seems, that the relation between them is broken ...
                                    It would be very handy to preserve the relation between original component and ghost during transportation between files.
                                    For example wireframe ghost of a highpoly tree takes a while to generate and it isn't practical to do it every time you insert the tree into new model ..
                                    Very nice toolset Fredo πŸ˜„
                                    http://www.starlingarch.cz
                                    • fredo6F
                                      You should keep in mind that GhostComp is a conceptual plugin. Really, what it does should be done in native by SU, and in a much more efficient way. To preserve the links between files for components is simply not possible with the Ruby API as it is today.
                                        ALFRED
                                        Hello! I am from Russia. Warning! my english is very bad!, Thanks Fredo for a magnificent plug-in πŸ‘ , it some kind of rescue for users of weak computers at work in 3d window, by the way, would be very abruptly if this plug-in could be used as "Vray Proxy" πŸ˜‰ Π‘an Vray use the Ghost components during visualization?
                                        • fredo6F
                                          Pavel,
                                          I don't know VRay, but I doubt the concept of proxy for Vray matches Ghostcomp.
                                          Actually, Ghostcomp is really conceptual. This is a good example of what Sketchup should do natively, in much better and simple way, including being able to connect the concept to rendering software.
                                            V-Ray for SketchUp cannot currently use proxies.
                                            • 2 / 6
