    πŸ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
    [Plugin] Bounding Box View
    20 Posts 15 Posters 23.7k Views 15 Watching
    • AdamBA Offline
      AdamB
      [flash=600,338:2wkarqp4]http://www.youtube.com/v/brkkFUpemjI[/flash:2wkarqp4]
      Right-click on a ComponentInstance and choose "Replace with Proxy Component" to flip it into a box.
      Right-click again to restore the original geometry.
      Available in the PluginStore
      Adam
        http://forums.sketchucation.com/viewtopic.php?f=180&t=21334
          DJMX1
          thanks, ghostcomp is great for far render, but bounding box is better for work immediately.
          • Chris FullmerC Offline
            I had worked on a script that replaced groups with more of a true bounding box, but never quite got it to do what I wanted it to do. I have some more ideas now, as I am learning more about Ruby and the SU API. But I would not ocunt on anything from me, especially seeing that Fredo is working on Ghost Comp.
            As for actually forcing the screen to stick on that level of bounding box detail, its not something that is do-able through Ruby. We can only come close, with things like ghostcomp.
            Chris
            All my Plugins I've written
              Hey Adam, thanks for this cool plugin. πŸ‘
              However, I do believe it would really deserve its own topic (marked with the [PLUGIN] tag for everyone's benefit). If you also agree, I can split this post off the above topic.
              • AdamBA Offline
                AdamB
                Sounds like a plan. I guess something like:
                [PLUGIN] Proxy View
                [Burn after reading πŸ˜„]
                  DJMX1
                  Thank you Adam. Your plugin is based Ghostcomp really! is very useful but I still am disappointed, I just want an even lighter than wireframe in order to turn quickly in a complex scene.
                  NORMAL VIEW with shadows
                  http://img2.pict.com/02/ac/49/1521277/0/800/1.jpg
                  BOUNDING BOX VIEW apply automatically when the computer is on its knees
                  http://img2.pict.com/6b/fd/c6/1521278/0/800/2.jpg
                  i want to control myself this view 😎
                    rv1974
                    @adamb said:
                    I mentioned sometime ago I'd post the LightUp version of this. So here it is - just put the Ruby in your plugins folder.
                    Adam
                    Adam if only you could make proxy boxes be rendered as original components (on export 2d grafics) it'd be the greatest break thru!
                    • AdamBA Offline
                      AdamB
                      What you're asking is Level-of-Detail switching which is going to be clunky in SU. You could do something that watched the camera position etc but its a real hack. So what you ask is something for Google not me. 😞
                      Ah, well if you're using that very fine LightUp software, this happens automagically when you switch to Tourtool mode.
                      Adam
                        tfdesign
                        Adam, I can't seem to get this plugin to work.
                        If I right click on a component, the component doesn't box up. If I click it again, it disappears altogether.
                        Any clues? Mac OSX perhaps?
                        My book "Let's SketchUp!" Download from here
                          tfdesign
                          Got the proxy plugin working- but only with specific types of components, ie it doesn't seem to work with 2D components (not that this really matters at this stage though πŸ˜„ )
                          Tom
                          • Didier BurD Offline
                            Didier Bur
                            I also have a plugin called "proxy" on the RLD: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=599 by A. Billyard: "Swaps component definitions with bounding boxes."
                            Does this one do the same thing ? Apparently yes.
                            DB
                              david23lara
                              Just AWESOME! thanks!
                                alien_killer
                                Thanks alot mate... i hope it works with vray.... one reason i moved to Max was cause of proxies.... but SKP is the best
                                • ccaponigroC Offline
                                  ccaponigro
                                  I love this plug in. If it did batches or mixed selections I'd be over the moon. I like to make all my furniture and appliances proxies and switch them back for viewing or publishing but doing them one at a time is a bummer.
                                  cfcaia.com
                                  • sdmitchS Offline
                                    sdmitch
                                    cc, I have sent you, by personal message, my version of Bounding Box View. It works with individual components or a selection.
                                    http://sdmitch.blogspot.com/
                                      ccaponigro
                                      Got it and using it! Works great I place all my heavy components on a layer and use select all on layer and bingo a punch of simple boxes.
                                      Here is a little trick. Some times snaping to a point on some components can be a pain. So I just make a proxy move or copy it using the proxy rectangle which is easy to find points on and then just switch it back.
                                      Anyway thanks!!!
                                      cfcaia.com
                                        Spartipilo
                                        I liked a lot this plugin, until I had a bugsplat, and my autosave didn't store the original models of the proxy cubes.
                                          rutpin
                                          I installed the finder plugin but I can't find it in my Scap, I right-click and it's not found, what do I do?
                                          • P Offline
                                            pedroaugsto Newcomers
                                            Proxy View plugin does not reveal the component.
                                            Suddenly the plugin stopped working, and I have all my blocks stuck in the proxy. Not returning to component.
