    [Plugin] Bounding Box View
    21 Posts 16 Posters 25.8k Views 16 Watching
    • GaieusG
      Hey Adam, thanks for this cool plugin. πŸ‘
      However, I do believe it would really deserve its own topic (marked with the [PLUGIN] tag for everyone's benefit). If you also agree, I can split this post off the above topic.
      • AdamBA
        AdamB
        Sounds like a plan. I guess something like:
        [PLUGIN] Proxy View
        [Burn after reading πŸ˜„]
          DJMX1
          Thank you Adam. Your plugin is based Ghostcomp really! is very useful but I still am disappointed, I just want an even lighter than wireframe in order to turn quickly in a complex scene.
          NORMAL VIEW with shadows
          http://img2.pict.com/02/ac/49/1521277/0/800/1.jpg
          BOUNDING BOX VIEW apply automatically when the computer is on its knees
          http://img2.pict.com/6b/fd/c6/1521278/0/800/2.jpg
          i want to control myself this view 😎
            rv1974
            @adamb said:
            I mentioned sometime ago I'd post the LightUp version of this. So here it is - just put the Ruby in your plugins folder.
            Right-click on a ComponentInstance and choose "Replace with Proxy Component" to flip it into a box.
            Right-click again to restore the original geometry.
            Adam
            Adam if only you could make proxy boxes be rendered as original components (on export 2d grafics) it'd be the greatest break thru!
            • AdamBA
              AdamB
              What you're asking is Level-of-Detail switching which is going to be clunky in SU. You could do something that watched the camera position etc but its a real hack. So what you ask is something for Google not me. 😞
              Ah, well if you're using that very fine LightUp software, this happens automagically when you switch to Tourtool mode.
              Adam
              • T
                tfdesign
                Adam, I can't seem to get this plugin to work.
                If I right click on a component, the component doesn't box up. If I click it again, it disappears altogether.
                Any clues? Mac OSX perhaps?
                • T
                  tfdesign
                  Got the proxy plugin working- but only with specific types of components, ie it doesn't seem to work with 2D components (not that this really matters at this stage though πŸ˜„ )
                  Tom
                  • Didier BurD
                    Didier Bur
                    I also have a plugin called "proxy" on the RLD: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=599 by A. Billyard: "Swaps component definitions with bounding boxes."
                    Does this one do the same thing ? Apparently yes.
                    DB
                      david23lara
                      Just AWESOME! thanks!
                        alien_killer
                        Thanks alot mate... i hope it works with vray.... one reason i moved to Max was cause of proxies.... but SKP is the best
                        • ccaponigroC
                          ccaponigro
                          I love this plug in. If it did batches or mixed selections I'd be over the moon. I like to make all my furniture and appliances proxies and switch them back for viewing or publishing but doing them one at a time is a bummer.
                          cfcaia.com
                          • sdmitchS
                            sdmitch
                            cc, I have sent you, by personal message, my version of Bounding Box View. It works with individual components or a selection.
                            http://sdmitch.blogspot.com/
                            • ccaponigroC
                              ccaponigro
                              Got it and using it! Works great I place all my heavy components on a layer and use select all on layer and bingo a punch of simple boxes.
                              Here is a little trick. Some times snaping to a point on some components can be a pain. So I just make a proxy move or copy it using the proxy rectangle which is easy to find points on and then just switch it back.
                              Anyway thanks!!!
                              cfcaia.com
                                Spartipilo
                                I liked a lot this plugin, until I had a bugsplat, and my autosave didn't store the original models of the proxy cubes.
                                  rutpin
                                  I installed the finder plugin but I can't find it in my Scap, I right-click and it's not found, what do I do?
                                  • P
                                    pedroaugsto Newcomers
                                    Proxy View plugin does not reveal the component.
                                    Suddenly the plugin stopped working, and I have all my blocks stuck in the proxy. Not returning to component.
                                    • G
                                      gallucpa
                                      Funziona correttamente, ... v.2013, ... per ora, πŸ™‚
