    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 141.6k Views 50 Watching
      BTM
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=btm_Sculpt_Tools_Files
      It should now be = >= v2014 compatible too...
      These are v 1.0 of sculpt tools, including:
      •bulge and push (shift to reverse both)
      •smooth
      •smudge
      •grab (works like a soft move at 100%)
      •…and a planar lock feature.
      (Tool settings accessible in the dialog tool.)
      … Although I was planning on adding an inflate feature, it was too unreliable to post yet. It may be included in a later release though, eventually.
      Features include different 'brush styles', gravity effect, planar lock, and more.
      http://forums.sketchucation.com/download/file.php?id=30348&t=1
      NOTES:
      •I will be unable to update the plugin for some time, so if a bug is found, or someone feels to fix anything, an 'unofficial version' section of this post may be added by a moderator, if a 'better' version is submitted by another ruby coder.
      •…Also, planar locks can't be moved, as they will function as though they weren't. The DO however stop working when their group is deleted. I unfortunately couldn't use the set_attribute function as I had hoped, but it should do for now.
      J 1 Reply Last reply Reply Quote 0
      • Chris FullmerC Offline
        WooHoo! I got the first download. I'm looking forward to playing with this, thanks BTM. Well done!
        Chris
        EDIT: I also fixed up the .zip file and replaced the file in your original post. So now it should be user friendly. Please let me know if I broke something in the process 😄
        All my Plugins I've written
        • K Offline
          kwistenbiebel
          Thank you BTM 👍
          I can't get it to work properly though...
          After triangulating a cube 4 times (SDS) and selecting the geometry, the tools remain unresponsive. I tried to adjust the radius but that didn't solve it.
          Any chance of giving us a little walkthrough on how to use it?
          Cheers,
          Kwistenbiebel
            BTM
            @kwistenbiebel said:
            Thank you BTM 👍
            Cheers,
            Kwistenbiebel
            Most tools should work by left-clicking, hold, and dragging across the surface. As to a walkthrough, I'll have no time in the near future 😳 . Also, by unresponsive, do you mean waiting-time, or no effect at all? Do you see the radius circle (blue)? Also, open up the ruby console, to see if there are any errors.
            • EarthMoverE Offline
              EarthMover
              Attaboy! Can't wait to give it a try. I think BTM stands for Break The Mold...cause that is what you did with this ruby! I hope all the polygons it creates doesn't break my machine. LOL
              EDIT - Had a quick play and everything seems to be working. What I've noticed -
              1. Turning off "display edges" helps to speed it up
              2. Turning on use sun for shading and playing with the light and dark sliders will help see what your sculpting
              3. It's a little unresponsive when dragging across a mesh.
              4. Mesh needs a decent amount of subdivision to generate smooth sculpting.
              5. Using Simple Loft works well to make a base sculpting mesh because you can set your subdivisions. Sandbox from scratch also works well.
              Since BTM doesn't have time to do a video, maybe as a community we can put together our observations, or if we have some good success, we can make a quick video for him.
              BTM, this could go down as one of the all time greatest plugins...it's a shame you couldn't better document it. Perhaps when you get more time.
              Content Creator at Skapeup
                MrWip
                Thanks BTM, that's seems very promissing !
                But, I'm a bit sad, because I get the same problem than Kwistenbiebel. The beta version whas working really fine on my sketchup 6.4 Pro, but now, with the latest one, nothing happened.
                I can see the icons, adjust the settings, but when it comes to use a tool, I can't see the blue radius, and my clics does not creates any movements on my triangulated shape...
                I've check the Ruby console, and It give me this :
                C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:86
                Error: #<NoMethodError: undefined method `pick' for nil:NilClass>
                ... I guess that the !NilClass! is not something good... do anyone have any idea what's wrong there ?
                http://www.wip-archi.com
                  BTM
                  I think it involves the first @model.start_operation line of the scripts; in SU6, the second param is different from SU7.
                  Try This: when it says @model.start_operation "Sculpt Bulge", false, true
                  set it to: @model.start_operation "Sculpt Bulge", true
                  if that doesn't work, then get rid of the , true part altogether.
                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#start_operation
                  • CadFatherC Offline
                    CadFather
                    Thanks BTM - hope you have a 'smoove' holiday round the corner.. looks amazing..
                    EDIT: i've just noticed it conflicts with 'soap skin' - the latter will not work properly (on PC)
                      CADAddict
                      I am using it with SketchUp Pro 6 and don't seem to work. The plugin appears on Plugins Sculpt, but when i try to sue it nothing happens...Maybe I am doing something wrong...
                      http://www.cad-addict.com/
                      • EdsonE Offline
                        Edson
                        hi BTM,
                        what does "PC friendly" means? that it won't work on mac?
                        http://www.mahfuz.arq.br
                          CadFather
                          i think BTM writes his plugins on a mac - so he probably means it will not have unknown bugs on pc which he can't always foresee
                          • EdsonE Offline
                            Edson
                            max,
                            well thought of. otherwise, why would one working on a PC worry about producing something PC-friendly? thanks.
                              MrWip
                              Thanks BTM for your quick reply.
                              First of all I've try the plugin on my (bugging) sketchup 7, and it works just fine.
                              Then I've try to do the changes you've recommended on each ruby script :
                              (@model.start_operation "Sculpt Bulge", true) or (@model.start_operation "Sculpt Bulge")
                              But, I always ended with an error message at the startup, about a syntaxe problem:
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:4: syntax error
                              Copyright 2009, btmsketchup@hotmail.com
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:6: syntax error
                              THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:7: syntax error
                              IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:10: Illegal octal digit
                              Created by •BTM on 23/07/09.
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:12: syntax error
                              Name: Bulge (sculpt tools)
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:13: syntax error
                              Version: 1.0
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:14: syntax error
                              Description: Bulges geometry on a mesh, in a way similar to 'brushing' on the mesh.
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:15: syntax error
                              Usage: Set the settings of the tool with the Sculpt Tools Dialog, and use it by 'brushing' on the mesh, with the left mouse button held down.
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:16: syntax error
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:43: syntax error
                              @entities.each do |e|
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:55: syntax error
                              @apns.each do |p|
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:56: syntax error
                              @sculptlocks.each do |l|
                              C:/Program Files/Google/Google SketchUp 6/Plugins/btm_Sculpt_Tools/btm_Sculpt2_Bulge.rb:69: syntax error
                              I've checked the previous version (beta) which was working on skp 6, and there was no 'false, true', just as you said... but sadly the same trick does not seems to work anymore...
                              ...I guess the other users reporting problems have encounter the same bug ...
                              I really hope there will be a way to solve it, because that's a really great script !
                                CADAddict
                                Ok, the plugin works fine with Sketchup 7 Free version, so I guess there is some issue with version 6.
                                • mitcorbM Offline
                                  mitcorb
                                  Thanks, -BTM,
                                  I will check out the latest release, mindful of the current feedback.
                                    I made some changes so that it should work in version 6 now. I've already changed the file in the first post. Someone who uses 6 want to download it and see if ti working better in v6 now? It should still work just the same in version 7.
                                    Chris
                                    • urgenU Offline
                                      urgen
                                      ...In SU5 the plugin works well 👍....thanks!
                                      --pupil forever...------
                                      • K Offline
                                        kwistenbiebel
                                        Thanks BTM and Chris for the update.
                                        works well in SU6 now 👍
                                          MrWip
                                          Just Perfect on Su 6 now, thanks a lot you two !
                                          • mitcorbM Offline
                                            mitcorb
                                            This latest version seems to work well in SU6 on my machine, even though it is an older unit (processing/reaction time is slow).
                                            Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.
                                            mitcorb
                                            • 1 / 5
