    Sketchup+VrayMax
    70 Posts 20 Posters 16.4k Views 20 Watching
    • N Offline
      nomeradona
      @marked001 said:
      wow... missed this post before.....this is just beautiful! great great great image..
      thanks mark that you found it.. hehehe.
      visit my blog: http://www.nomeradona.blogspot.com
      • 9 Offline
        9fly
        Very good image and lighting. How long did it take for you to complete this scene. I meant only for render compare with VR4SU
        • N Offline
          nomeradona
          honestly i found vray max much faster than vray for su in terms of render. the rendering of this higher subdivision is about 31 minutes as you can read below the image. and im really tweak this with higher render time of maximising the image sampler subdivision. my minimu material subdivion is 24.. comparing with vraySU i would say that the scene will be around an hour or more. not including the parsing time. with a huge number of polygons. VraySU parsing time will be longer inspite of the fact that texture are applied inside the group or even using the remove CGmaterials ruby.Because of this you will see more and more that i will render using VRAYmax. because i found the trick of exporting my SU model at ease with the workflow explained previously.
          • N Offline
            nomeradona
            some more images
            http://farm3.static.flickr.com/2505/3786819231_510bc06e8b_b.jpg
            http://farm4.static.flickr.com/3504/3786822255_dd872c69a9_b.jpg
            http://farm3.static.flickr.com/2550/3787637872_7158214131_b.jpg
            • N Offline
              nomeradona
              my girls bedroom
              http://farm3.static.flickr.com/2525/3787660584_ccce88b32e_b.jpg
              • N Offline
                nomeradona
                new stuff
                http://farm3.static.flickr.com/2540/3787882674_e58212c6fb_b.jpg
                http://farm3.static.flickr.com/2633/3787883816_a16ba083ac_b.jpg
                http://farm4.static.flickr.com/3591/3787077265_a14a1a315c_b.jpg
                • N Offline
                  nomeradona
                  last one rerendering old su model, exported to max and finally rendered with VrayMax 1.5
                  http://farm4.static.flickr.com/3576/3787971784_9d6468cf92_b.jpg
                  http://farm4.static.flickr.com/3457/3787160953_10d0ace27c_b.jpg
                  • holmes1977H Offline
                    holmes1977
                    Nomer you are the SHADOW KING 😎
                    Exaggeration makes a dull story better.
                    • stefanqS Offline
                      stefanq
                      Max it's awesome....and you, of course!
                      • N Offline
                        nomeradona
                        thnaks holmes.. i think i like that name πŸ˜„
                        • N Offline
                          nomeradona
                          @stefanq said:
                          :shock:
                          funny while learning max, i begin to find something and apply them with vraysu
                          http://farm3.static.flickr.com/2582/3788678590_dbf179061e_b.jpg
                          http://farm4.static.flickr.com/3569/3787880794_de7906c1dc_b.jpg
                          • urgenU Offline
                            urgen
                            ....πŸ‘ πŸ‘ πŸ‘ β˜€
                            --pupil forever...------
                              steelers05
                              Great work Nomer. I am currently working on a model to render in max, and seeing your images is inspiring me...your making it look it easy. I hope I find the process as easy as you have been saying.
                              • N Offline
                                nomeradona
                                thanks urgen...
                                • N Offline
                                  nomeradona
                                  i should say, with this process, i am now more keen to produce my output in vraymax since my modelling soft is still SU. as again it has 0 parsing time.
                                    alex luu
                                    these are very fantatis!
                                    the lighting is great and meterials are wonderfull!
                                    i like them!
                                    i am only jealous of your ability
                                    πŸ‘ πŸ‘Š
                                    Everyone has limit,let try your best to cross this limit!
                                    please contact with me when you need help to show your idea!
                                    Hope to work with you!
                                    archpaint1711@gmail.com
                                    skype: alex_luu1711
                                    • massimoM Offline
                                      massimo Moderator
                                      Great images indeed. Only a little question, did you model the wood planks in last two images or is just a texture?
                                      • N Offline
                                        nomeradona
                                        i like them!
                                        πŸ‘ πŸ‘Š
                                        thanks alex.. now that must be a flattery cause i know your ability...
                                        • N Offline
                                          nomeradona
                                          i used bump texture, but i have to do my own bump.
                                          i only higlighted further the groove by painting black. then I applied a suttle gaussian blur to have a softer transition.
                                          • massimoM Offline
                                            massimo Moderator
                                            Ok, thanks and congratulations. πŸ‘
                                            • 2 / 4
